#3071 | |
When a new data file is created, the default option settings are initially used - these can then be changed using the Tools > Options menu command. Different data files can have different saved settings. Best wishes for the New Year to you also. Kind regards, David
www.hornresp.net |
#3072 |
Hi David,
Thanks that's good to know, and fixes my problem. :-) Regards,
Oliver |
#3073 |
I note that you are receiving numerous requests to extend the functionality of your HR program. In this regard, an offer of a commission (financial reward), organized by those making the requests, might be sufficient encouragement for you to implement them.
TAD uses a resonant cavity in their AFAST Horns to suppress response ripple that increases as horn cut-off frequency [Fc] is approached. Regards, Bill |
#3074 | |
Fortunately for us there's not much Hornresp can't do, and whatever is left over can be continued in Akabak. |
#3075 | |
And a very happy New Year to you also! Unfortunately most of the requests now being received would require major modifications to the Hornresp architecture to enable them to be implemented in a rigorous and consistent fashion. It is not a question of financial inducement, but rather the amount of work involved in making any such changes. As you know, the program has evolved significantly over the years, but with little alteration to the fundamental user interface or input parameters. I guess, like me, Hornresp is beginning to show its age... :-). Kind regards, David
www.hornresp.net |
#3076 | |
i can imagine that todays computers are fast enough to do the caculations pretty quick. otoh,its not a necessity
one good thing about music ,when it hit you feel no pain. so hit me with music.
#3077 |
Hi David,
New Year, new requests? :-) When simulating OD horns I'm using Ap1/Lpt to control the entry into the horn at the S2 location, and this seems to work. I think I'm simulating an entry into the horn with a throat chamber coupling duct that has a cross-section smaller than S2. I would like to additionally have the ability to simultaneously provide a vent for the rear chamber, similar to the way you solved this for CH, by using S4/S5/L45 for the rear chamber port/horn. Would that be possible without major modifications? Regards,
Oliver |
#3078 | ||
Hi Oliver,
Kind regards, David
www.hornresp.net |
#3079 | |
David,
I noticed some kind of 'sudden jump' when sliding Vrc and the appearance of 'Helmholtz freq' in the lower right corner. (red color) The graph suddenly changes a lot too. Sliding further in the Vrc normally doesn't change the graph a lot, except at this certain point. Attached are the two screen shots with a Vrc difference of only 0.1 Thank you.
![]() Quote:
#3080 |
i stumbeled to this recently.
it also hapens when you slide the port lenght
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
