Hornresp
Hornresp
Old 16th December 2012, 06:26 AM   #3041
klampykixx is offline klampykixx  Australia
very good. thanks, ill have to re-assess what i end up doing as the new result is very different from what i had. :/
Old 19th December 2012, 06:43 AM   #3042
David McBean is offline David McBean  Australia
Default Hornresp Update 3020-121219
Hi Everyone,
There were some inconsistencies in the operation of the 'Compare Captured' menu command. This bug has now been fixed.
The Loudspeaker Wizard baseline for combined responses assumed unmasked resonances even when the masked option was selected. This bug has now been fixed.
Kind regards,
David
www.hornresp.net
Old 19th December 2012, 09:50 AM   #3043
Thawach is offline Thawach  Thailand
Thawach's Avatar
thank u david for the update, i come too late because very busy to update ur fhornresp. i spent many times to update cause that im very busy. all the thing will be ok with the new version.
Old 19th December 2012, 12:11 PM   #3044
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
@David:
I'm guessing you do what I do. Check the program against a well known file. If the output is strange, then somethings afoot!
Thanks for keeping on your toes David.
Mark
www.kravchenko-audio.com
Old 19th December 2012, 02:36 PM   #3045
epa is offline epa  Netherlands
yup ,i discovered it yesterday.
tnx david
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 19th December 2012, 08:06 PM   #3046
Don Hills is offline Don Hills  New Zealand
Originally Posted by David McBean View Post
... This bug has now been fixed. ...
The first law of cybernetic entomology: there's always one more bug.
Old 19th December 2012, 11:47 PM   #3047
Originally Posted by mwmkravchenko View Post
I'm guessing you do what I do. Check the program against a well known file. If the output is strange, then somethings afoot!.
Hi Mark,
Nothing so organised as that :-). I tend to just keep trying different things at random, and every now and then I notice something that is not working as it should. That is how I found the latest two bugs.
Kind regards,
David
www.hornresp.net
Old 19th December 2012, 11:58 PM   #3048
Hi Don,
Love that law - it's so true :-).
Every time I think I must have finally found the last bug in Hornresp, it's not long before another one pops up. I have come to the conclusion that they must be breeding inside the program.
Kind regards,
David
www.hornresp.net
Old 20th December 2012, 12:05 AM   #3049
Hi Thawach,
Thanks for the suggestion you made in Post #2802 - you will have seen by now that it was possible to implement it successfully .
Kind regards,
David
www.hornresp.net
Old 23rd December 2012, 02:23 PM   #3050
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Eee PC 1000HD laptop & Windows XP. I tried multiple times.
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
