Hornresp
Hornresp
Old 9th December 2012, 04:49 AM   #3021
David McBean is offline David McBean  Australia
Originally Posted by David McBean View Post
For space reasons the combined response chart no longer has the word "Combined" in the title either "Masked" or "Unmasked" is shown instead.
The attached worst-case examples show more clearly why it was necessary to omit "Combined" from the combined response chart title.
Kind regards,
David
www.hornresp.net
Old 9th December 2012, 02:52 PM   #3022
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Hornium unoptanium?
Yep bugs bunny latin!
Always improvements. Cannot say thank you enough.
Still like the performance and power out of your example horn setup David.
Mark
www.kravchenko-audio.com
Old 9th December 2012, 08:39 PM   #3023
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Ditto!
Old 10th December 2012, 05:38 AM   #3024
Thanks Mark. As you can imagine, finding a driver with a Pmax of 9999 W and Xmax of 99.9 mm took quite some doing :-).
Kind regards,
David
www.hornresp.net
Old 10th December 2012, 10:33 AM   #3025
Mark Kravchenko
Hornresp
Never say never David.
I'm working with Dan on a driver design with exactly that much X-max in each direction. Difficult, but not impossible.
As for the power handling, well turn to your closest electric stove, and multiply it by two.
Mark
Old 11th December 2012, 05:53 PM   #3026
Josh Ricci is offline Josh Ricci  United States
David,
Is there any chance of adding more complex 3 part inductance modeling to HR? Perhaps with a box to mark it as in effect or "off" which would use 1khz LE still.
Old 12th December 2012, 03:19 AM   #3027
Hi Josh,
Sorry, no chance - I like to keep things as simple as possible :-).
Kind regards,
David
www.hornresp.net
Old 12th December 2012, 10:58 AM   #3028
more10 is offline more10  Sweden
David
Is there any chance of adding Helmholz chambers in between segments? This would be very useful when trying to supress resonances in transmission lines.
Is there any chance of adding ports in between segments? This would be very useful for simulation of some bass reflex enclosures. I would like to simulate swapping placement of port and driver in JBL 2226 ported something I built from srx boxes
And thanks for your fantastic software!
Old 12th December 2012, 12:57 PM   #3029
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Default All I want for Christmas is....
Hi Khron,
Sorry, but I have no plans to add incoming signal filtering functionality to Hornresp.
My interest lies with the performance of the loudspeaker itself - not with how the signal is processed prior to reaching the loudspeaker :-).
Kind regards,
David
David
I am fully aware of your stance on adding a signal filter function to Hornresp and when I mentioned the lack of same on the other thread I did not make a request directly to you.
Differents results from differents simulation sofware
But since this is the place to discuss these things I will post my reasons here:-
Most systems do not have a flat signal to 10Hz, for most audio systems such an extended LF would result in driver damage.
For bass reflex designs and tapped horns, a hi-pass filter is a necessity above a fairly low power level, and must be concidered as an integral part of the design process.
There is also the QB5 reflex alignment that uses a port tuned for a resonant peak and a filter to reduce cone excursion and give a resultant extended flat reponse.
Satellites and Subwoofers
I do feel that it would be a great addition to your software and would result in some very creative designs.
Kind regards
Martin (Xoc1)
Old 12th December 2012, 03:17 PM   #3030
epa is offline epa  Netherlands
hi martin
i opted a simular question a few pages back.
Originally Posted by epa Click the image to open in full size.
hi david
is there any sofware that you (or anybody else)now of ,that can import hr data ,to model a filter/eq .
this would be helpfull to determen a hpf.
tnx erik
Hi epa,
Thats easy to do: You only need to convert the HR textfile to a format that any of these program can recognize:
FRD Consortium
PS: I usually first import the .wav files from HR to HOLMimpulse where I edit the IR/FR and then export to e.g. MPRM program where you can do all filtering/ Eq. and the back to Holmimpulse to present the resulting graphs you want to display.
bClick the image to open in full size.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
