Hornresp
Hornresp
Old 30th November 2012, 11:40 PM   #3011
GM is offline GM  United States
GM's Avatar
No problem for me from either HR or the link in DB's sig. line.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st December 2012, 01:37 AM   #3012
Sabbelbacke is offline Sabbelbacke  Germany
No Prob here.
Old 1st December 2012, 04:55 AM   #3013
littlemike is offline littlemike  United States
Thanks. Clearly there is an issue on my end.
Old 1st December 2012, 05:58 AM   #3014
John Sheerin is offline John Sheerin  United States
It's not just you. I can't load the page either.
Old 1st December 2012, 07:16 AM   #3015
David McBean is offline David McBean  Australia
Hi John,
I just checked - no problems for me using the www.hornresp.net.ms address.
Not sure that it will make any difference but you could perhaps try Hornresp instead.
Kind regards,
David
www.hornresp.net
Old 1st December 2012, 07:49 AM   #3016
Default Hornresp Update 3010-121201
Hi Everyone,
A few minor code refinements have been made. They do not affect the results or alter the operation of the program in any way.
Kind regards,
David
www.hornresp.net
Old 1st December 2012, 06:41 PM   #3017
tb46 is offline tb46  United States
Hi Y'all,
Just downloaded the latest version, no problems accessing the website, new version loaded/unzipped/installed/works fine (Windows XP SP3).
Thanks David,
Oliver
Old 1st December 2012, 06:44 PM   #3018
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Me to!
Maybe you need to refresh your page in your browser Mike.
Mark
www.kravchenko-audio.com
Old 1st December 2012, 09:31 PM   #3019
Things appear to be working properly now. Thanks all.
I'm thinking it was an ISP issue for me, as I could not reach the site via any of my PCs at home or work. I tried on multiple machines, using several operating systems, and on different networks, but using the same ISP.
Old 9th December 2012, 05:24 AM   #3020
Default Hornresp Update 3020-121209
Hi Everyone,
Changes are:
1. The phase response calculated with 'resonances masked' is now more accurate at the higher frequencies.
2. Group delay with 'resonances masked' can now be calculated. Previously even with the masked option selected, the group delay assumed that resonances were not masked.
3. Combined response with 'resonances masked' can now be calculated. Previously even with the masked option selected, the combined response assumed that resonances were not masked. For space reasons the combined response chart no longer has the word "Combined" in the title either "Masked" or "Unmasked" is shown instead. This means that the combined response is now identified solely by the inclusion of the path length difference in the title - see attached screenprint.
4. Previously, if horn 2 in a compound horn system had a parabolic flare, the Loudspeaker Wizard could not be selected. This bug has now been fixed.
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
