Old 25th November 2012, 09:15 AM   #3001
AndrewT is online now AndrewT  Scotland
Unzip shows an error.
What do I need to do?
Old 25th November 2012, 09:32 AM   #3002
jwmbro is offline jwmbro  United States
jwmbro's Avatar
You probably need to run the extractor as admin - win7 blocks access to some low level or system folders by default.
Alternatively try extracting to somewhere else.
Regards, James
Old 25th November 2012, 09:35 AM   #3003
I am administrator, I am the only user.
All previous versions installed.
Old 25th November 2012, 10:17 AM   #3004
jwmbro's Avatar
I don't mean that you have to be an administrator, I mean that you have to run as administrator. Right click the file --> run as admin
Regards, James
Old 25th November 2012, 10:28 AM   #3005
I am the only user.
My access is administrator !
Closed the open Hornresp, that told me that there was a new version.
This allowed the newly downloaded setup to run.
Old 25th November 2012, 11:45 AM   #3006
jwmbro's Avatar
I am the only user.
OK I'm glad you were able to fix your problem. However whether or not you are the only user or whether or not you are administrator has no effect on how the program is run in Windows 7.
If you don't run a program like this, it won't be able to access certain system files, regardless of what type of user you are on. But apparently that was not the problem in this situation.
Regards, James
Old 25th November 2012, 12:09 PM   #3007
I am always administrator.
Sometimes it is a nuisance, eg seeing two versions of a folder. One accessible and one that does not allow access, even to the administrator.
Old 26th November 2012, 05:05 AM   #3008
Hi Andrew,
As you have discovered, it is necessary to close the existing version of Hornresp located in the C:\Hornresp folder, before a new version can be unzipped to the same folder. It is not possible for the open file to be over-written.
Kind regards,
David
www.hornresp.net
Old 30th November 2012, 09:57 PM   #3009
Is anyone else unable to reach the hornresp download page? I have been trying since the last update was announced with no success.
Old 30th November 2012, 09:59 PM   #3010
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
It's working for me ATM
Dan
Hornresp Class FlipC Subwoofers 8 3rd November 2008 06:23 PM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2013 diyAudio
