Hornresp
Hornresp
Old 24th November 2012, 04:37 AM   #2991
David McBean is offline David McBean  Australia
Originally Posted by tb46 View Post
Thank you both, your explanations are very much appreciated.
Hi Oliver,
Please continue to query any Hornresp results that may seem a little strange.
It prompts me to conduct further tests to ensure that the simulation models are indeed operating correctly :-).
Kind regards,
David
www.hornresp.net
Old 24th November 2012, 04:44 AM   #2992
Originally Posted by epa View Post
how do i export*.wav from hr?
Hi epa,
Select the Tools > Impulse > Response menu command from the SPL Response chart window, and then click the Export button.
Kind regards,
David
www.hornresp.net
Old 24th November 2012, 09:13 AM   #2993
Sabbelbacke is offline Sabbelbacke  Germany
@Björn
Returned from work after daaaaays and just clicked your screenshot.... What nice looking peace of software ist this you are building there?
Old 24th November 2012, 09:27 AM   #2994
epa is offline epa  Netherlands
tnx again david.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 24th November 2012, 12:29 PM   #2995
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
Originally Posted by Sabbelbacke View Post
@Björn
It's a horn simulation SW When I started going really deep into horn theory some years ago, I also started writing horn simulation SW to better understand the physics involved. While I had Hornresp, I both wanted to understand what was going on behind the scenes, and to try some of my own ideas. Over the years (since early 2006) it has evolved to a quite complex program that does most of what Hornresp does, plus and minus some things.
David and I have had quite a lot of discussion and exchange of ideas about horn simulation over the years, and David has helped me a lot, especially in the beginning. I hope I have contributed to some useful features in Hornresp in return
The plan is to release HornCAD to the public some day, but it will not be freeware for two reasons: We already have an excellent piece of free horn SW in Hornresp, and it is not my intention to compete with it. The other reason is that I have a day job, and if I am to provide support anywhere near the level of Hornresp, I need to get paid for the time I spend.
However, I could use a couple of Beta testers
-Bjørn
Dynamics to the people!
Old 24th November 2012, 12:31 PM   #2996
mwmkravchenko is online now mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Default Volunteer number one.
If I can help I would be pleased to be a tester.
Mark
www.kravchenko-audio.com
Old 24th November 2012, 01:33 PM   #2997
Kolbrek's Avatar
Thanks, Mark. You've got a PM
Old 24th November 2012, 01:43 PM   #2998
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Please, could someone model this for me? I am too stupid to learn Hornresp, I downloaded it and tried to, really!
tb46 already tried to simulate my plans of a ppsl sub which has it's own thread here A bench style cabinet subwoofer 2x15 closed and final plans from message #25 on. SEe attached sketches below.
I'll use two Dayton Classic 15" drivers in series, connected push-pull in separate identical 258 liter closed boxes.
The slot plenum is 100mm wide and 420mm high, max depth is 420mm but the rear side of it is rouded with a hemispherical filling. Plenum opening area is 420 cm2 and it is on floor level in a 10,5 m2 room (2,6x3,65x2,55m). The edge of top board makes a 25mm lip on top of the plenum, the board is 40mm thick.
Thank You in advance,
Juha
AINOgradient speaker project
Old 24th November 2012, 03:23 PM   #2999
Kolbrek's Avatar
Now I have my Beta testers, I think two is enough for starters. Thanks, guys!
-Bjørn
Old 25th November 2012, 04:59 AM   #3000
Default Hornresp Update 3010-121125
Hi Everyone,
Opening the Data File Editor and selecting a file name but then cancelling out of the tool without saving, could sometimes cause the attached fatal error to be generated when later navigating through the Hornresp records.
This bug has now been fixed.
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
