| Thread Tools | Search this Thread |
#21 |
I just had the same problem with the tapped horn feature. Just make it 4 segments instead of 3 and it works again. I like the slide feature. It took me a few tries to get agile, but then it speeded up the process of alignment tremendously.
David, you are updating at an alarming rate! What more can we expect? I would be interested in a tapped horn alignment wizard (enter length and driver and the wizard sorts out optimal driver position, that sort of thing). But, to be honest, I'm getting pretty good results without it.
I sehs there is no stronger breastplate, than the heart that is undainted. |
#22 |
Thanks Ivo, that work around works.
Oliver |
#23 |
Hi everyone who like the same...same.
David tell me that now he is working hard for a new version. he can not answer everyone because he is busy because me. i think the next version will coming soon. the name may be change that the Hornresp thawach Version. David are u o..che?lol |
#24 |
No rush, plenty to do myself...
#25 |
Ivo! don't too old . still young....still young will be happy.
#26 | |
![]() Excursion of a 2x15" TH looks like this: ![]() So at 60Hz there is a max. Now using max-SPL feature with 1,8kW and 9,6mm xmax gives: As far as I understand it, the xmax-feature gives a response curve depending on whether xmax or max power is reached. Input Power here was 1800 Watt, xmax was defindes as 9,6mm. So if theoratical excursion would be 27mm when driven with 1800 watts, its more than xmax. Therefore xmax should be the limiting factor at 60 Hz. hornresp claims "power limited" though. Looking at a simulation of a closed design with a different speaker (18") looks like this: ![]() with xmax at 9,8mm and 1250 Watts. The Limitation in the low end is obvious. Here the sample-feature gives a correct "excursion limited"
#27 | |
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#28 |
Well, I downloaded it again and re-installed it to see if it would cure my problem, but now I can't view any of my previous three segment TPs, THs, without first adding a 4th section, plus none of the wizard's fields are working right.
![]() GM
#29 | |
I should have spent more time on pre-release testing - two obvious errors slipped through :-). The problems have now been rectified. A subtle bug that I discovered recently in the Wavefront Simulator has also been fixed. Kind regards, David |
#30 | |
You are not missing anything :-). Thanks for bringing the error to my attention - it has now been fixed. Product Number 1830-080408 refers. Kind regards, David |
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 07:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 10:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 04:56 PM |
| Page generated in 0.12287 seconds (69.42% PHP - 30.58% MySQL) with 11 queries |
