Hornresp - Page 298 - diyAudio
Old 15th November 2012, 04:01 AM   #2971
Originally Posted by tb46 View Post
Just tested the new version, and it seems to work just fine. Thank you so very much.
Hi Oliver,
You're most welcome :-).
Thank you for continuing to report any bug that you find, and for supplying such comprehensive supporting information - it makes it that much easier for me to track down the source of the problem.
With your help, perhaps one day Hornresp will be completely bug free :-).
Kind regards,
David
www.hornresp.net
Old 15th November 2012, 05:57 AM   #2972
ßart West-VL.'s Avatar
Thanks David.
Admirable what you do for the DIY community!
Break in your loudspeakers at 35% RMS power Right-click'save as...'
Brown noise mono 192kbps(hit "repeat")
Old 15th November 2012, 07:06 AM   #2973
Originally Posted by ßart West-VL. View Post
Thanks David.
Thanks Bart. I have already found a new bug in Version 30.10 - see my next message :-).
Kind regards,
David
www.hornresp.net
Old 15th November 2012, 07:09 AM   #2974
Default Hornresp Update 3010-121115
Hi Everyone,
A new bug introduced into yesterday’s Version 30.10 release has now been fixed. An Ang value of 0.0 x Pi (infinite horn) would incorrectly generate an "invalid result" error message.
Kind regards,
David
www.hornresp.net
Old 15th November 2012, 11:39 AM   #2975
Mark Kravchenko
mwmkravchenko's Avatar
Bugs keep you busy David.
What would you be doing without them?
You must be captin of the swat team by now!
Mark
www.kravchenko-audio.com
Old 16th November 2012, 06:28 AM   #2976
I seems that I need to find a better insect repellent:-).
Kind regards,
David
www.hornresp.net
Old 16th November 2012, 06:34 AM   #2977
Default Hornresp and Windows 8
Hi Everyone,
I was wondering if anyone had tried running Hornresp on a new Windows 8 system yet.
I would be very interested to know if the program still works :-).
Kind regards,
David
www.hornresp.net
Old 18th November 2012, 04:36 AM   #2978
Default Message for Jean-Michel (Jmmlc)
Originally Posted by David McBean View Post
The accuracy of the Hornresp combined response impulse response waveform has been significantly improved.
Hi Jean-Michel,
I'm not sure if you still visit this thread, but if you do, I suspect that you might perhaps be wondering if the impulse response changes referred to in Post #2969 apply to your marvellous IR algorithm. They do not - your code remains untouched. A modification has however been made to the way that the phase values (used as one of the inputs to your routine) are specified.
Just thought you would like to know :-).
Thanks again for providing the IR algorithm used in Hornresp.
Kind regards,
David
www.hornresp.net
Old 19th November 2012, 07:22 AM   #2979
Jmmlc is offline Jmmlc  France
R.I.P.
Dear David,
For sure I visit that thread (weekly) and noticed the improvement brought by Bjorn Kolbrek to the exported IR.
As I always give my ideas and work in audio for free, be sure that I'll approve if my algorithms could be improved.
As the IR calculation is based on a quasi wavelet synthesis method I developped, I am sure that someone having better knowledge about wavelets than me can improve the routine if necessary.
Best regards from Paris,
Jean-Michel Le Cléac'h
Hi Jean-Michel,
Kind regards,
David
Old 20th November 2012, 07:04 AM   #2980
Hi Jean-Michel,
Personally I would be most surprised if anyone could improve on your algorithms - they are very elegant and efficient as they stand, and work extremely well :-).
Kind regards,
David
www.hornresp.net
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2017 diyAudio
