Old 13th November 2012, 07:52 AM   #2961
Originally Posted by NEO Dan View Post
It appears that Ap1 is not working for Nd and OD, then again it could be the pilot.
Hi Dan,
I just checked - it works fine for me.
Remember to double-click on the label, not the input box itself :-).
Alternatively, use the Tools > Chamber menu to make the selection.
Please let me know if you continue to have a problem.
Kind regards,
David
www.hornresp.net
Old 13th November 2012, 07:55 AM   #2962
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
I'm not having trouble selecting Ap1 mode, it's the function not working that's the problem. Ap works but Ap1 looks as if it's sealed/Fr mode...
Dan
Old 13th November 2012, 08:12 AM   #2963
Hi Dan,
Sorry, I misunderstood :-).
Could you please post Input Parameters window screenprints for two Nd and OD designs that are not working properly, so that I can investigate further.
Thanks.
Kind regards,
David
www.hornresp.net
Old 13th November 2012, 08:51 AM   #2964
NEO Dan's Avatar
Thanks David,
I went back to a previous record and loaded it up and waddya know, it works. Upon inspection I found out what I was doing WRONG, sorry for the distraction, carry on...
Dan
Old 13th November 2012, 10:11 AM   #2965
Mark Kravchenko --- www.kravchenko-audio.com
mwmkravchenko's Avatar
I think your little monkey needs new glasses Dan.
Mark
Old 13th November 2012, 10:48 AM   #2966
www.hornresp.net
Old 13th November 2012, 11:01 AM   #2967
I have to poke at him while he is sleeping!
I hope.
David am I dreaming in technicolor on the ability to change the graphs horizontal scale?
Don is right in stating you can do it in Akabak.
When I have to scale things I import them into REW and I can scale them quite easily.
Not that good with spread sheets yet.
But I'm guessing I should learn.
Mark
Old 14th November 2012, 04:31 AM   #2968
It seems so :-).
www.hornresp.net
Old 14th November 2012, 04:42 AM   #2969
Default Hornresp Update 3010-121114
Hi Everyone,
The accuracy of the Hornresp combined response impulse response waveform has been significantly improved. When an exported *.wav file is transformed back to the frequency domain, the resulting SPL response is now a lot closer to the original. The extent of the change is shown in the attached example.
My thanks to Bjørn (Kolbrek) for his help in the development of this enhancement.
The bug reported by Oliver in Post #2946 has now also been fixed.
Kind regards,
David
www.hornresp.net
Old 14th November 2012, 01:31 PM   #2970
tb46 is offline tb46  United States
Hi David,
Just tested the new version, and it seems to work just fine. Thank you so very much.
Oliver
Hornresp Class FlipC Subwoofers 8 3rd November 2008 06:23 PM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2013 diyAudio
