Hornresp
Hornresp
Old 22nd October 2012, 08:10 AM   #2941
rogozhin is offline rogozhin  Ukraine
rogozhin's Avatar
Hi, David!
Originally Posted by David McBean View Post
Hi Alexander,
That is very strange - normally I get a Postmaster message back advising me if an e-mail I send is not delivered successfully. I had "replied" to the question you asked, so my response should have gone direct to your 'rambler' address. I make a point of answering every e-mail I receive from Hornresp users - even when I know my reply may not be what they were hoping to hear :-).
Rambler works very bad last time But no matter.
It is highly unlikely that Hornresp will ever allow acoustic filling in the horn. While it might be okay for transmission line type speakers, as far as I am concerned it has no place in a well-designed horn system - artificially introducing a loss in the acoustic path seems to defeat the whole purpose of the exercise :-).
Kind regards,
David
Of course I speak about transmission lines and hybrid loudspeakers. Right designed horns don't need to be filled - It's true!
Hornresp very well and exact calculates the TL's! For full happiness missing only two things - ability to simulate offset port and losses by filling in channel of transmission (labirynth).
Thank you for replies! Alexander.
Old 22nd October 2012, 09:11 AM   #2942
David McBean is offline David McBean  Australia
Hi Alexander,
I assume you are aware of the following new simulation program? It seems to allow filling / stuffing to be specified.
http://www.diyaudio.com/forums/subwo...ml#post3179499
Kind regards,
David
www.hornresp.net
Old 22nd October 2012, 09:25 AM   #2943
Charcoal is offline Charcoal  Ukraine
David, one more question.
Will it be possible in future to simulate compaund horn and BReflex with LeCleach flare front horn?
Old 22nd October 2012, 10:11 AM   #2944
Hi Charcoal,
The way that Hornresp has evolved, a massive amount of work would now be required to modify the program to allow other than a parabolic, conical or exponential flare to be specified for the second or front horn in a compound horn design. Unfortunately I am not in a position to undertake such a large re-build of the software.
Kind regards,
David
www.hornresp.net
Old 24th October 2012, 06:28 AM   #2945
Default Hornresp Update 3000-121024
Hi Everyone,
Due to an oversight on my part, under some conditions the phase response chart when printed could be different to the chart displayed on the screen.
This problem has now been fixed.
Kind regards,
David
www.hornresp.net
Old 11th November 2012, 08:03 PM   #2946
tb46 is offline tb46  United States
Hi David,
I just ran into a small problem with the response display in the Wizard v. the SPL screen:
Oliver
Old 11th November 2012, 09:48 PM   #2947
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Are you referring to the difference in the resonance spike?
Would it be possible that if you matched the horizontal scale, you might see the same amount of details?
Or am I missing your point?
Mark
www.kravchenko-audio.com
Old 11th November 2012, 10:33 PM   #2948
Hi Mark,
I'm talking about the big spikes around 50-65Hz in the Wizard v. the small blips around 60Hz in the SPL screen. In this particular case it doesn't matter much, but, I thought David would like to see this.
I think both displays should be the same (how do I change the horizontal scale?).
Oliver
Old 11th November 2012, 10:46 PM   #2949
Mark Kravchenko
Hornresp
The graph on the right has a 2 khz bandwidth.
The graph on the left has a 20khz bandwidth.
Might explain the differences.
Mark
Old 11th November 2012, 10:58 PM   #2950
Hi Mark,
Yes, I noticed that, and thought that's what you are referring to, but how can I get them to be equal?
Oliver
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
