Hornresp
Hornresp
Old 19th October 2012, 06:57 AM   #2911
Charcoal is offline Charcoal  Ukraine
One question.
When resp make a draw of LeCleach horn, for example. Can I just upscale it in graphic soft and make the horn? Is Resp drawing horns with correct dimensions, proportions?
Old 19th October 2012, 08:33 AM   #2912
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
I guess it would be an accurate visual representation of an axisymmetric (round) horn, but realistically IMO you should make use of the export function to get the dimensional data to build the horn from.
Dan
Old 19th October 2012, 08:45 AM   #2913
Thanks a lot, only now I realised that profile can be exported also)
Old 19th October 2012, 03:13 PM   #2914
Ok, thats horn for 12 inch FR. One pic is resp image, another - xls built curve using exported file from resp, coordinates x nad y.
Both look quite different... Its a bit confusing to start extended woodworking with this)))
Old 19th October 2012, 03:16 PM   #2915
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Yep.
Been up against that for quite a while.
Maybe Mr. David could create something that would give us a true representation?
Mark
www.kravchenko-audio.com
Old 19th October 2012, 03:24 PM   #2916
Ok, I am quite gratefull to David for this FREE soft. At list I built a lot of labyrynths with it quite sucessfully, and conus horns also.
For JMLC - I am stuck on the midway. Also simulation of such 220Hz horn shows very smuth roll off to the low end.
Its pic with big volume of rear chamber, without acustic short circuit... Driver is a2 FR, with 95-96Db sensetivity
Even if will get the same curve but with lower SPL than resp shows - I will be still very happy)))
Old 19th October 2012, 03:57 PM   #2917
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
For LeCléac'h horns, Hornresp has the option to export an "exact profile", which uses an algorithm that is a little different than the original LeCleac'h algorithm, but it will give a horn that is closer to the profile the original algorithm tries to achieve. For simulations, Hornresp uses the original algorithm, and it is probably also used to draw the schematic. If you have answered yes to the question you get when exporting LeCléac'h horn data, you will get a curve that is slightly different from the schematic. If you answer no, you should get the exact representation of the schematic.
Attached is an attempt to illustrate that: I exported the horn data, imported it into excel, and pasted the excel graph on top of the hornresp schematic.
From what I can tell, you have used the "exact" option, since the other option does not extend the rollback further than what is shown in the schematic.
In any case, I would trust the exported data more than the schematic.
mwmkravchenko, have you experienced that there is a mismatch between the schematic and the exported data on a regular basis?
-Bjørn
Dynamics to the people!
Old 19th October 2012, 04:11 PM   #2918
Yes, I exported exact profile. On your picture differance is less than on mines.
Old 19th October 2012, 04:37 PM   #2919
Mark Kravchenko
Hornresp
Hey there Bjorn
Yes at least as of last time I did a large lecleach design it did not match.
Mark
Old 19th October 2012, 07:52 PM   #2920
can you show what you built? how than can one built "correct" jmlc horn?
how about response from hornresp, how close it is to real JMLC?
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
