#2901 | |
Thanks for the feedback. To better understand how the Hornresp Data File Editor works, try the following: 1. Create a new data file using the File > New menu command. 2. Open the Data File Editor using the File > Editor menu command. 3. Click on the Hornresp.dat file name in the top left or right box. 4. Select a number of Hornresp.dat records to move or copy to the new file, or to delete from Hornresp.dat. The Editor allows those Hornresp users with lots of records * to organise things better by storing their data in various different files if they wish. Kind regards, David * A Hornresp "Grand Master" is a user with more than 1000 records :-).
www.hornresp.net |
#2902 | |
You have assumed that X1 = 0. Isn't X1 the axial distance from the parabola vertex to the point at which Y = Y1? Kind regards, David
www.hornresp.net |
#2903 |
schmeet appears to have his x's and y's crossed...
"wires" crossed, get it? Oh, never mind... ![]() I think it should read: X1 = SQRT[S1 / PI] X2 = SQRT[S2 / PI] Y1 = 0 Y2 = L12 (Length) S for any value of Y can be found as follows: s = ((y - c) / a) * pi His method is the same as I have been using. I also like your method because it avoids converting from area to radius and back. |
#2904 |
I guess so, but it makes more sense to me that x is the axis along the length of the pipe and y is its radius.
#2905 | |
![]() The only difference between these two lines is PAR vs CON segments and my lines don't overlay nearly as nicely as yours. I noticed this problem almost immediately when Hornresp allowed PAR segments. I don't remember which model caused me the most trouble but I've seen examples much worse than I've posted here. As I pointed out originally this isn't a fatal flaw, it doesn't seem to shift the peaks right or left (which would be really bad) it just changes the amplitude a bit. Even though this isn't bad I would prefer to avoid surprises like this. In very large horns, 2 db at tuning can be a difference of hundreds of liters of enclosure size. I'd really like to be as accurate as possible when I fold. Although I haven't studied in depth what factor is causing this, I think it's one or more very long segments that will cause this discrepancy. (I got the mail, thanks!) Last edited by just a guy; 9th October 2012 at 01:31 PM. |
#2906 | |
Mark Kravchenko --- www.kravchenko-audio.com
lost 400+ a few years ago and have 440 Still not a grand master! But I'm working on it!
Mark |
#2907 |
True, it makes sense to "lay it on its side". The trouble is that you mixed your axes in your example - some of your values were for a "horizontal" parabola, some were for an "upright" parabola.
#2908 |
Hi Don and schmeet,
Thanks for the clarifications – everything makes sense now :-). In summary: Assuming that X is axial length and Y is radius, the equation used to define the parabolic curve should have been shown as: X = a.Y² + c Rather than: Y = a.X² + c This then gives: a = [X2 – X1] / [Y2² – Y1²] c = X1 – a.Y1² S = ((X – c) / a) * Pi Which provides the correct result. Kind regards, David
www.hornresp.net |
#2909 |
just a guy:
A very small spreadsheet is attached. All it does is calculate the csa at any point you specify along a conical segment. |
#2910 |
Thanks Don. I can't look at it at the moment (no excel on this laptop) but I'm sure it's just what I need to accurately fold my Akabak horns.
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
