#2791 |
#2792 |
You could think of the floor as a mirror of your horn. And speaking of response; depending on what your "requirements" are you might want to have a look at the off axis response. From the SPL screen do a [ctrl]+r.
Regards, Dan |
#2793 | |
You are correct in your thinking. Starting with S1 = 49, S2 = 2500 and L12(Exp) = 60 , I get a slightly different result to yours, but nothing to worry about. Length...Height...Width 0...........70........70 100........67.......142 200........85.......213 300........123.....285 400........189.....357 500........303.....428 600........500.....500 Kind regards, David
www.hornresp.net |
#2794 | |
Thanks for the feedback - knowing that Hornresp is proving to be useful and that my efforts are valued, is all the reward I need :-). Kind regards, David
www.hornresp.net |
#2795 |
I want to use this cabinet to match speaker i have.
I want guidance for hornresp input. I have done but i think i need some guidance specially for ATC. Please tell me if my hornresp inputs are correct or not? So i need master's( David McBean) guidance if possible. |
#2796 |
ATC looks good, but VTC appears to have an error... VTC should represent the volume of the cone and the cutout in the baffle, looks like an extra 0 in there.
Regards, Dan |
#2797 |
Thanks Dan,
I calculated the area marked as Vtc. The calculation is as under 42.07 width till horn starts 10.6 height 57.4 depth of the box. so it calculated as 42.07 x 10.6 x 57.4 = 25597 + added speaker volume 4403. So i rounded as 30000. The triangle volume i adjusted towards round cutout of plywood . Pl. correct me. |
#2798 |
Probably best to define it as a segment to enable Hornresp to more accurately do it's job IMO
Regards, Dan |
#2799 |
The throat chamber is a segment that calculates it's length via the ATC and volume you provide, but as I stated above a more accurately defined model is...
Regards, Dan |
#2800 |
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
