Old 31st August 2012, 10:58 AM   #2781
BP1Fanatic's Avatar
Yeah he is! It's the best enclosure building tool EVER!
Old 31st August 2012, 09:12 PM   #2782
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Hi David,
I'm seeing some odd behavior in going between the Wizard and the plot of the resulting saved design, looks like they are not using the same math?
Dan
Old 1st September 2012, 06:53 AM   #2783
Originally Posted by mwmkravchenko View Post
I keep an eye on the version numbers. You are keeping very busy David.
Hi Mark,
There will be yet another minor update in the next few days :-).
Kind regards,
David
www.hornresp.net
Old 1st September 2012, 07:02 AM   #2784
Hi Dan,
Could you please post a specific example (with screenprints if possible), to enable me to replicate your results and to then investigate the problem further. Thanks.
Kind regards,
David
www.hornresp.net
Old 1st September 2012, 01:57 PM   #2785
NEO Dan's Avatar
Originally Posted by David McBean View Post
Hi Dan,
Kind regards,
David
Here's what I have David.
Code:
ID=29.00
Ang=2.0 x Pi
Eg=48.99
Rg=0.00
Fta=-1.28
S1=2000.00
S2=1937.50
Par=25.00
F12=0.00
S2=1937.50
S3=1062.50
Par=350.00
F23=0.00
S3=1062.50
S4=1000.00
Par=25.00
F34=0.00
S4=0.00
S5=0.00
L45=0.00
F45=0.00
Sd=840.00
Bl=11.65
Cms=3.64E-04
Rms=3.29
Mmd=137.64
Le=2.98
Re=3.76
TH=1
Vrc=0.00
Lrc=0.00
Ap1=0.00
Lpt=0.00
Vtc=0.00
Atc=0.00
Pmax=100
Xmax=5.0
Comment=test file
Code:
New                                                            Old 2900-120413
Click the image to open in full size. Click the image to open in full size.
Dan
Old 2nd September 2012, 07:51 AM   #2786
Hi Dan,
Many thanks for the example - the problem was confined to negative flare parabolic horn segments only. The bug has now been fixed - Product Number 2910-120902 refers.
The latest release also includes a change to the schematic diagram horn data export functionality. Previously the width of a rectangular cross-section could only be specified indirectly by entering the height (see attachment 1). Now either the height or width dimension can be entered directly (see attachment 2) .
Kind regards,
David
www.hornresp.net
Old 5th September 2012, 11:59 AM   #2787
Am I doing this correctly?
I'm guessing the increments are on the axis going through the center of the horn?!
Daniel
Old 5th September 2012, 12:28 PM   #2788
David,
I appreciate all your hard work in this product.
Obviously your an audio/computer nut!
Keep it going.
Since you give it away what would be an apropriate donation?
System: Hitachi HT-320, HK 330a, Energy 3.1e speakers and xbox360, android phone headphone out for hirez FLAC playback.
Old 5th September 2012, 12:52 PM   #2789
Mark Kravchenko --- www.kravchenko-audio.com
mwmkravchenko's Avatar
+1
Mark
Old 5th September 2012, 02:02 PM   #2790
NEO Dan's Avatar
Daniel
That'll do, but if you are going to have the horn on the floor you can use a flat bottom.
Happy SketchUping
Dan
Hornresp Class FlipC Subwoofers 8 3rd November 2008 06:23 PM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2013 diyAudio
