Hornresp
Hornresp
Old 17th June 2012, 07:48 PM   #2731
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
what i get out af al reply's ,high cr is certenly doable but you need a sort of phase plug/rings to compensate path differences.
No.
The phase plugs are there for the purposes of pushing up high frequency response. That was the purpose of the papers posted by Mr. |Geiger. The papers were written to describe means and methods used to push up high frequency response of drivers in high frequency horns. As stated before you can push up the efficiency of a bass horn by means of the compression ratio. But you have to choose your balancing. Many drivers will survive higher pressures than you might think in the home setting. Truth to be told is that we don't push them all that hard for long periods of time. So bottom line is experiment, simulate, and carefully layout your horns. If you build them as per your simulation hornresp is very accurate at predicting what they will perform like.
1 pascal = 0.000 145 037 738 01 pound/square inch.
So roughly ten thousand pascals to one PSI.
Choosing the right cone makeup will let you work with higher pressures. So pick a cone that you can't deform to easily with your hands.
Mark
www.kravchenko-audio.com
Old 17th June 2012, 09:35 PM   #2732
tb46 is offline tb46  United States
Hi mwmkravchenko,
"...pushing up high frequency response..."
I just posted a mid-range horn with the Selenium 10PW3 in Post #188 here: http://www.diyaudio.com/forums/subwo...oldier-19.html Do you think it will make 2kHz?
Oliver
Old 17th June 2012, 09:59 PM   #2733
Mark Kravchenko
Hornresp
Some basics.
Your throat must be smaller than the wavelength of sound you wish to create. If it is larger than the upper frequency you wish to reproduce it will not work so well.
Next.
You need a driver that will get you this high in frequency response anyway. This is directly related to the drivers voice coil inductance. Remember that to large an inductance cuts out high frequency. And there is pretty much nothing you can do about it.
Driver choice is very important. So as a quick way to figure out the high frequency response try the driver out in hornresp in a sealed or vented enclosure. The low end is unimportant take a look at the high frequency response.
Mark
Old 17th June 2012, 11:32 PM   #2734
Hi Mark,
Thanks, I've tried this, and the sealed response is down 6dB @ 200 and 2kHz. The wavefront simulator in the horn version actually still looks good @ 2kHz.
I'll attach the Hornresp Input screen.
Oliver
Old 18th June 2012, 12:35 AM   #2735
2Pi loading means the speaker is on a boundary for all frequencies in the passband. Wavelength of 2kHz is ~170mm
regards Andrew T.
Old 18th June 2012, 08:59 AM   #2736
David McBean is offline David McBean  Australia
Less roughly, 6895 Pa = 1 psi :-).
Kind regards,
David
www.hornresp.net
Old 18th June 2012, 12:47 PM   #2737
Mark Kravchenko
Hornresp
Hard to argue when you're right.
Thanks for the correction.
Mark
Old 18th June 2012, 03:24 PM   #2738
Hi David,
I found something I don't understand (well, nothing new there). Going into an existing simulation, I went to Edit/Tools/System Design/From Specification/Yes/200/2000/OK, and the program calculated new horn values for S1/S2/Hyp. That was expected. But then I noticed that the program also changed the Mmd from 12.89 to 1.61. Bug, or feature? Version 29.10 Product Number 2910-120519.
Oliver
Old 18th June 2012, 03:33 PM   #2739
epa is offline epa  Netherlands
not sure ,but i think what it means that the horn throat is specified and and it "creates" the ideal driver.
oliver,why not give jbell a pm,ask his findings(he's been there done that.
grtz erik
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 18th June 2012, 04:47 PM   #2740
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
Originally Posted by tb46 View Post
Hi David,
If you want to keep the driver, you should use System Design/With Driver. System Design From Specification also calculates driver parameters, but I have never seen a case where only Mmd changes. Usually other driver parameters change as well.
Bjørn
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
