Old 8th June 2012, 10:21 AM   #2681
Mark Kravchenko --- www.kravchenko-audio.com
mwmkravchenko's Avatar
Always happy to give credit where it is due.
And speaking of possible changes.
How about making it possible to start a tapped horn with a negative flair in stead of a normal expanding flair?
That little detail has it's uses.
Don't know how difficult it would be to implement though.
Mark
Old 9th June 2012, 06:14 AM   #2682
Hi Mark,
As far as I know, it should already be possible - see attached screenprint.
Are you having problems generating a negative flare?
Kind regards,
David
www.hornresp.net
Old 9th June 2012, 04:21 PM   #2683
Originally Posted by David McBean View Post
...and I have run out of things that can be readily added to the program...
regards,
David
Any chance of more comprehesive instructions? For a complete newbie like myself I struggle to understand what data I should be entering where. Maybe some pictures in the help?
Old 9th June 2012, 06:53 PM   #2684
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Here is an example of entering driver parameters:
Originally Posted by NEO Dan View Post
I was not thinking of the DVC, so the LE looked high to me. Here are the corrected inputs for 2 woofers wired as a 4Ω nominal load.
Hint: Start by entering SD and double click in Cms, Mmd, Bl, Rms, and answer the questions to enter the parameters.
Click the image to open in full size. Click the image to open in full size.Click the image to open in full size.
Dan
Old 10th June 2012, 02:22 AM   #2685
Thanks NEO Dan... Fairly right with the driver parameters, as those can be found in the specs and matched to what Hornresp uses.
Just a passing thought, but maybe a cheap and cheerful spec converter in the app? For the novice like myself it would be nice to know the specs provided by the driver manufacturer have been converted properly for use in the app.
Some times the spec are represented in a way that is totally foreign and unknown, and it just add a layer of uncertainty to the process, so some smarts around entering the driver parameters would be extremely helpful.
Generally we tend to gain a reasonable amount of familiarity with T/S specs over the years just looking at different drivers, but I am struggling with the box parameters more than anything. I find it hard to visualise what Vtc, Atc etc etc do, as before opening this program I had never seen or heard of them.
I also see a lot of folded boxes as the finished product, but Hornresp shows a tube like result, I understand that the folded box is just a result of folding the tube, but some pictures that show where the box parameter are located / look like in a folded box, would really help a visual person like myself.
To better illustrate my point a thought just come to mind... I have been writing an app myself that visually demonstrates the effect of changing template guides and router cutters, and show the dimension on the same page as the specs like this...
Old 10th June 2012, 06:08 AM   #2686
Hi Silent Screamer,
Google is your friend - try a search using the key words "Hornresp tutorial".
Kind regards,
David
www.hornresp.net
Old 10th June 2012, 06:25 AM   #2687
Hi Silent Screamer,
The Calculate Parameter tool enables Thiele-Small parameter values to be converted to their electro-mechanical equivalents, for use in Hornresp.
Try altering the input values, to see how the schematic diagram changes.
Vtc is the volume of the horn throat chamber and Atc is the cross-sectional area.
Kind regards,
David
www.hornresp.net
Old 10th June 2012, 09:23 AM   #2688
Neo said
But that is not the order for columns then rows, nor for rows then columns.
What order is best for entering data into Hornresp?
Old 10th June 2012, 09:43 AM   #2689
NEO Dan's Avatar
Originally Posted by AndrewT View Post
Neo said But that is not the order for columns then rows, nor for rows then columns.
Left to right top to bottom. The same way we read and write here on the forum.
When in doubt use the tab key... Hornresp knows what's next even if you don't.
Dan
Old 10th June 2012, 09:47 AM   #2690
Where does Re and Le and TH fit into the order?
Hornresp Class FlipC Subwoofers 8 3rd November 2008 06:23 PM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2013 diyAudio
