Hornresp
Hornresp
Old 18th May 2012, 08:53 AM   #2661
epa is offline epa  Netherlands
hi david
the reason for asking was realy to compare system volume(to see how much the volume has grown/shrinked) after adjustments in the loudspeaker wizzard.
until now i just remember the volume of the original,but sometimes i got it mixxed up
grtz erik.
btw this driver arangement tool makes things verryclear for everyone.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 18th May 2012, 08:58 AM   #2662
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
Re the need to having to "capture results" to compare two combined response plots etc. Would it be possible to inlcude an option for "always calculate combined response"? Or a key combination (Ctrl+F5 for instance) to to that right away?
Bjørn
Old 18th May 2012, 09:34 AM   #2663
David McBean is offline David McBean  Australia
Hi Erik,
The Loudspeaker Wizard memory feature can be used to readily compare system volumes - use shortcut keys F1 to F4 to store up to four different designs and keys Ctrl+F1 to Ctrl+F4 to recall those designs.
Kind regards,
David
www.hornresp.net
Old 18th May 2012, 09:44 AM   #2664
just right click "capture current results" then it holds all data of the current screen.
Or alternatively, press Ctrl+C to capture the current results, Ctrl+X to release captured results.
Kind regards,
David
www.hornresp.net
Old 18th May 2012, 09:47 AM   #2665
tnx david
i learned something today.
. hr driver db
Old 18th May 2012, 12:54 PM   #2666
tnx david
Hi Erik,
It's all in the Hornresp Help file... :-).
Kind regards,
David
www.hornresp.net
Old 18th May 2012, 01:06 PM   #2667
Hi Bjørn,
While it would certainly be possible, I am reluctant to make such a change :-). To be consistent and for the sake of completeness, ideally the same functionality should then also be provided to enable the immediate generation / direct comparison of directivity responses, maximum SPL responses and multiple speaker responses. Because of the way that the Hornresp menu structures have evolved, I can foresee a number of problems in trying to do this without having to completely re-build the user input interface. Unfortunately this is not something that I am in a position to do at this stage - sorry :-).
Combined response can of course be directly calculated if the Loudspeaker Wizard is being used...
Kind regards,
David
www.hornresp.net
Old 21st May 2012, 11:08 AM   #2668
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Is it possible to do a compression section with Hornresp?
Hear the real thing!
Old 21st May 2012, 11:21 PM   #2669
Don Hills is offline Don Hills  New Zealand
If you mean a section with decreasing area (tapering down from a large area to a smaller area): Yes, you can.
Old 21st May 2012, 11:39 PM   #2670
soongsc's Avatar
Looks like I'll give it a try. Thanks.
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
