Hornresp
Hornresp
Old 18th March 2012, 11:47 AM   #2651
David McBean is offline David McBean  Australia
Originally Posted by Dag Johansen View Post
I found it!
Hi Dag,
That is excellent news :-).
Kind regards,
David
www.hornresp.net
Old 18th March 2012, 12:19 PM   #2652
What's a Dropbox?
How does one set it up?
Does using one have any downsides?
regards Andrew T.
Old 18th March 2012, 04:27 PM   #2653
littlemike is offline littlemike  United States
Originally Posted by AndrewT View Post
What's a Dropbox?
2 GB+ of free cloud based personal storage that seamlessly syncs between multiple PCs.
https://www.dropbox.com/
I'm not affiliated, just a user. If I refer you and you sign up, I get more storage though... If interested, PM me an email address, I'll send you a referral.
Downsides? No ads or anything like that, and no cost. Maybe that it is limited in size, and that syncing takes time. Also - it does not exactly protect from deletion or overwriting, because any changes you make propagate through the system. I use it a lot though, works well for me. I can sync my data between several desktops and laptops seamlessly.
Old 19th March 2012, 03:52 PM   #2654
epa is offline epa  Netherlands
the hr.dat file (in my case) has 350 sims,and is only 127 kb.
just put on a usb stick or back it up anywhere (except on the c drive)
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 17th May 2012, 09:42 PM   #2655
jwmbro is offline jwmbro  United States
jwmbro's Avatar
Hi David!
Thanks for your great program. I just updated from I think v25 or so to v29, lot's of fancy new features I still need to play around with.
But one problem I have encountered (not a bug, just something I'd like to see), is that when you want to simulate multiple speakers, you need to simulate twice. First you simulate the single speaker, then you Ctrl+K in the multiple speakers. This works fine, but with one problem. When you use the "compare previous" function, it compares to the single speaker of the same type.
But what I was trying to do was compare 2 of one speaker with 3 of the other speaker. I was able to do this by creating a new "metasub" with 3 times the S1-S5 of the actual sub, and with 3P drivers in it. As far as I can tell, this sims the same as 3 individual speakers. But it would be nice to be able to skip this step of creating a new record somehow. Hope I'm not the only would who would love to see this.
Thanks.
PS: just realized - the same applies to vented designs, as you have to first sum the driver, and then the combined response. so you can't really compare two reflex boxes with one another I think.
Regards, James
Old 17th May 2012, 09:53 PM   #2656
just right click "capture current results"
then it holds all data of the current screen.
use f4 button to compare the captured data to compare with your new data.
@ david
for the wishlist if possible,it would be nice to compare the schematic daigrams
regards erik
. hr driver db
Old 17th May 2012, 10:00 PM   #2657
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
I've been running hornresp from a dropbox for quite a while now and the only snag is if you happen to open hornresp on more than one PC/Mac at a time, that will cause a conflicted copy of the database file to be created. Which is the proper thing to do IMO.
Dan
Old 17th May 2012, 10:01 PM   #2658
jwmbro's Avatar
Great, thanks a lot epa! I was thinking there might be such a function somewhere that I was missing, that's exactly what I was after. Carry on.
Regards, James
Old 18th May 2012, 08:43 AM   #2659
Hi Erik,
I tried experimenting with schematic diagram comparisons some time ago, but the combined drawings can get quite messy so I decided not to include the feature in Hornresp - I like things to look nice and tidy :-). It is of course possible to export the horn data for different designs, and to compare the profiles in Excel or similar.
Kind regards,
David
www.hornresp.net
Old 18th May 2012, 08:46 AM   #2660
Default Hornresp Update
Hi Everyone,
Hornresp Version 29.10 has just been released.
The data input form used with the Driver Arrangement and Multiple Speakers tools now includes a schematic diagram showing the specified driver / speaker configuration. See the example screenprint attached.
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
