Hornresp - Page 261 - diyAudio
Old 20th February 2012, 04:47 AM   #2601
Default Hornresp Update
Hi Everyone,
The Loudspeaker Wizard bug reported by bjorno and mdocod has now been fixed.
The latest release is Product Number 2900-120220.
Kind regards,
David
www.hornresp.net
Old 20th February 2012, 07:36 AM   #2602
David...Wow, what a wonderful tool you've created. I've been using Hornresp for about 1.5 years now, and it just keeps getting better. Thank you for all of your hard work.
Old 20th February 2012, 08:35 AM   #2603
3GGG is offline 3GGG  Australia
How do i sim a large (3 metre wide bass horn (stand or underground) like the ones Jean-Michel is a massive fan of?
http://img209.imageshack.us/img209/7...024x768qs8.jpg
Old 20th February 2012, 02:08 PM   #2604
tb46 is offline tb46  United States
Default Post #2601
Hi David,
The last update seems to work great. Thank you so much for adding the isobaric driver feature to your product.
Oliver
Old 20th February 2012, 04:06 PM   #2605
MaVo is offline MaVo  Germany
Hello David,
In the attached image you can see two phase plots. The only parameter difference between both is the box volume, in one pic its 262l in the other 261l. Should this happen?
regards,
Mathias
Old 20th February 2012, 07:44 PM   #2606
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi 3GGG,
Here is a template: The submitted .txt file to import and tweak using an another driver + adding more CSA:s and sections ,of course, if you want. I fiddled with a horn mouth of 3x2 meters
b
File Type: txt pd2450-h.txt (477 Bytes, 7 views)
Old 20th February 2012, 08:27 PM   #2607
The PD2450 sims well there and is no1 runner for me currently. Need 20Hz to 110Hz
With a fold that horn looks doable. In hornresp how do i sim a 60cm high horn (similar in design to lazy cats horns and similar but on a smaller scale to those bass horns in Milano), not a circular horn?
Old 20th February 2012, 09:13 PM   #2608
I never designed a large sub horn with an aspect ratio larger than 4:1 so for Your 5:1 design: I hand over this question to whom this is an easy question to answer.
b
Old 22nd February 2012, 03:51 AM   #2609
Hi Trackzilla and Oliver,
You're welcome. Thanks for the thanks :-).
Kind regards,
David
www.hornresp.net
Old 22nd February 2012, 04:07 AM   #2610
In hornresp how do i sim a 60cm high horn, not a circular horn?
Hi 3GGG,
For the purposes of the simulation, assume that the horn is axisymmetric (circular). At bass frequencies the predictions will be accurate enough. A horn mouth 3 metres wide x 60 cm high will have a cross-sectional area of 18000 sq cm.
Kind regards,
David
www.hornresp.net
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright 1999-2017 diyAudio
