Hornresp
Hornresp
Old 7th February 2012, 06:26 AM   #2551
David McBean is offline David McBean  Australia
Originally Posted by bjorno View Post
They will change too in a IMO weird way as BL Rms and Mmd will be UN-recognizable if doing a real world measurement.
Hi bjorno,
I am not sure how to interpret the results you have posted :-).
To establish a starting point reference - what are the theoretical parameter values for a single Audiobahn AW1251SE driver?
Thanks.
Kind regards,
David
www.hornresp.net
Old 7th February 2012, 06:31 AM   #2552
Originally Posted by tb46 View Post
I'll just stay with my old method of calculating the values for an isobaric pair, and treating it like a single driver in Hornresp.
Hi Oliver,
I would be very interested to know what method you use to calculate the single driver equivalent parameter values for an isobaric pair. Thanks.
Kind regards,
David
www.hornresp.net
Old 7th February 2012, 06:47 AM   #2553
Originally Posted by jamikl View Post
I got back online on Saturday and find I am unable to connect to David McBean's new link.
Hi jamikl,
The current Hornresp link is Hornresp. The webpage is very kindly hosted by Sabbelbacke in Germany.
I have noticed that file download times have been significantly slower over the past week or so, but I don’t know the reason why.
Do you have a dial-up or a broadband Internet connection?
Kind regards,
David
www.hornresp.net
Old 7th February 2012, 07:05 AM   #2554
Originally Posted by Jmmlc View Post
Seems OK to me too.
Still the problem of the inverted phase on the phase graph ... (wrap around + and -180° and not around 0°).
Thanks Jean-Michel.
I have no idea why my reply to mimura was posted twice, 28 minutes apart :-).
I get the phase response shown below - isn't this correct?
It seems to be wrapped around 0 degrees okay.
Kind regards,
David
www.hornresp.net
Old 7th February 2012, 07:35 AM   #2555
Jmmlc is offline Jmmlc  France
R.I.P.
Hello David,
Your phase graph is correct.
Here is the one I obtained with the new version of Hornresp downloaded few minutes ago.
Attached is the Hornresp record mimura.txt I used.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Originally Posted by David McBean View Post
Thanks Jean-Michel.
Kind regards,
David
File Type: txt mimura.txt (419 Bytes, 3 views)
Old 7th February 2012, 08:44 AM   #2556
Hi Jean-Michel,
The reason for the difference in our results is that you are using the 'unmasked resonances' option and I am using the 'masked resonances' option.
I am not sure why this should have such an effect on the phase wrapping process - I need to investigate further :-).
Kind regards,
David
www.hornresp.net
Old 7th February 2012, 08:47 AM   #2557
jamikl is offline jamikl  Australia
Hi David, I'm using ADSL2+. If I wait long enough I get the "Web page is not Available"message. I've been trying for three days now - same result each time. I never had any problems two and a half months ago on the same computer. Don't know what is wrong now.
jamikl
Old 7th February 2012, 12:21 PM   #2558
mimura is offline mimura  Thailand
Hello David,
Hello David and all the members.
Thanks for the help. I do not know if it will affect projects that are going to do it. I do not know much about such details.
Thank you for good.
Old 7th February 2012, 01:53 PM   #2559
tb46 is offline tb46  United States
Default Post #2554 - Isobaric Driver Configuration
Hi David,
I'll attach a screen print of some notes in a spreadsheet. Using these values seems to work well enough. Please, let me know if you find any big mistakes.
Oliver
Old 7th February 2012, 02:48 PM   #2560
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi bjorno,
Thanks.
Kind regards,
David
Hi David,
A starting point reference is single coil DVC TS parameters that can be found here: The submitted picture
b
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
