Hornresp
Hornresp
Old 26th January 2012, 07:12 AM   #2531
Sabbelbacke is offline Sabbelbacke  Germany
I had the same diskussion about port end correction with the german author of Ajhorn. After simulating dozens of designs, building them up for real nad comparing the results, we figured it was not necessary to bother
If one yould be very picky about the behaviour of ports, we would also have to look after the exakt positioning of the port (relaitve to the transducer oder other radiation sources in the same frequency domain), the distance to the end of the port inside the enclosure to the adjancing walls, if the port is close to the floor, etc...
This site hosts a little peace of software conncerning flares on ports, I never checked if the results are any good (I only use some other soft for calculating resonances), but maybe he has some insight no the topic?
Flare-it - Free Speaker Design Software
Old 26th January 2012, 09:39 PM   #2532
Twellmann is offline Twellmann  Denmark
Hello all
I have a question in regards to the throat chamber, when there is more than one driver.
If I model a horn with e.g two drivers, Hornresp shows the combined area of both SD's , Vtc and Atc. But placing two drivers in the same physical space is somewhat difficult, so obviously I need two throat chambers and perhaps two rear chambers??! (think offset horn with drivers on either side)
My question: Do i simply divide the Atc by two and keep Ltc as it is (thickness of plywood). I'm inclined to say yes, comparing it to reflex ports, but things aren't always as simple as they seem
Old 28th January 2012, 04:30 AM   #2533
David McBean is offline David McBean  Australia
My question: Do i simply divide the Atc by two and keep Ltc as it is (thickness of plywood). I'm inclined to say yes, comparing it to reflex ports, but things aren't always as simple as they seem.
Hi Twellmann,
The important thing is to maintain the same total chamber volumes as used in your Hornresp two-driver simulation.
The two drivers in the actual built loudspeaker can share a single rear chamber of volume Vrc and depth Lrc, or each driver can have its own separate rear chamber of volume Vrc / 2 and depth Lrc.
Similarly, the two drivers can share a single throat chamber of volume Vtc and area Atc, or each driver can have its own separate throat chamber of volume Vtc / 2 and area Atc / 2. The depth Ltc does not change.
Kind regards,
David
www.hornresp.net
Old 28th January 2012, 12:47 PM   #2534
Originally Posted by David McBean View Post
Hi Twellmann,
Kind regards,
David
Great, thanks
Old 3rd February 2012, 06:17 AM   #2535
Default Hornresp Update
Hi Everyone,
The Help file now has a Find tool. Product Number 2890-120203 refers.
Kind regards,
David
www.hornresp.net
Old 3rd February 2012, 05:58 PM   #2536
Many thanx David for the ongoing effort!!
Old 3rd February 2012, 06:02 PM   #2537
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
I need all the help i can get.
Great!
Mark
www.kravchenko-audio.com
Old 4th February 2012, 08:47 PM   #2538
tb46 is offline tb46  United States
Hi David,
Thanks again, another useful feature.
How about adding an Isobaric button to the "Driver Arrangement" window? To automatically calculate the proper T/S parameters for an isobaric pair, with the choice of series or parallel drivers resulting from the "Drivers connected..." windows. This might be another really helpful feature.
Oliver
Old 6th February 2012, 04:27 AM   #2539
mimura is offline mimura  Thailand
Hi David,.
Help analyze. The Sim's look at what's wrong or not.
Thank you.
ID=28.80
Ang=2.0 x Pi
Eg=2.83
Rg=0.00
Fta=12.40
S1=470.00
S2=800.00
Con=59.10
F12=0.00
S2=800.00
S3=1974.00
Con=66.00
F23=0.00
S3=1974.00
S4=3705.00
Con=71.80
F34=0.00
S4=3705.00
S5=6564.00
Con=51.70
F45=0.00
Sd=1225.00
Bl=27.95
Cms=7.94E-05
Rms=8.76
Mmd=156.26
Le=1.79
Re=5.40
Nd=1
Vrc=91.00
Lrc=16.00
Ap1=0.00
Lpt=0.00
Vtc=4500.00
Atc=1250.00
Pmax=1200
Xmax=5.0
Comment=c18-650el
Old 6th February 2012, 06:10 AM   #2540
Hi Oliver,
To fully integrate a rigorous isobaric model into Hornresp would require a massive amount of work. Given that the configuration is rather specialised and of somewhat limited application, I can't see myself undertaking such an ambitious project :-).
It is already possible however, to generate a reasonably accurate prediction in Hornresp using a simplified isobaric model which ignores the air volume between driver diaphragms.
PROCESS:
To model an isobaric driver array in Hornresp, specify the electrical series / parallel connection using the Driver Arrangement tool, and set Sd equal to the driver diaphragm piston area of a single driver divided by the number of drivers in the array.
For example, if the diaphragm piston area of each driver in an isobaric pair is 500 sq cm then set the value of Sd in Hornresp to 250 sq cm. The Driver Arrangement tool will automatically double this back to 500 sq cm when 2S or 2P is selected.
The attached chart shows the power response from one side of an isobaric driver pair connected in parallel and mounted in an infinite baffle. The red trace shows the Hornresp prediction using the simplified model and the blue trace shows the AkAbak result for the complete model - taking into account the effect of the air chamber between the two diaphragms.
The AkAbak response is marginally lower than the Hornresp response at higher frequencies due to the additional moving mass of the air volume between the drivers. The spike in the AkAbak response at 8600 hertz is due to a half-wavelength resonance in the air cavity.
For the purposes of the simulation the air volume between the drivers is assumed to be 1 litre, with the diaphragms being separated by an average distance of 2 centimetres.
Mass of 1 litre of air = 1.205 grams
Chamber half-wavelength resonance = 1 / 2 x 34400 / 2 = 8600 hertz
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
