Hornresp - Page 249 - diyAudio
Old 18th December 2011, 01:20 PM   #2481
Mark Kravchenko
mwmkravchenko's Avatar
Thanks David!
I just tried it on a midrange horn I'm fooling around with. It is quite intuitive. Thanks for the suggestion Bjørn.
It's not the wizard, but it is really quite fast.
The new help format is indeed easier to read as well.
Thanks again David. These refinements are making a powerful program easier to use. All a big bonus!
Mark
www.kravchenko-audio.com
Old 18th December 2011, 03:57 PM   #2482
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Thank you Santa! I will have to drill this into muscle memory. :^]
Dan
Old 18th December 2011, 07:47 PM   #2483
Mark Kravchenko
Santa????
I think it's really David.
Much better than some pigment of your imagination Dan.
Mark
Old 19th December 2011, 05:33 AM   #2484
NEO Dan's Avatar
It's coal for you slacker, now back to work
Dan
Old 19th December 2011, 06:41 AM   #2485
Originally Posted by mwmkravchenko View Post
Santa???? I think it's really David.
Hi Mark,
How did you ever guess?
See my photo below - I told you I was old... :-).
Kind regards,
David (aka Santa)
www.hornresp.net
Old 19th December 2011, 07:08 AM   #2486
Originally Posted by David McBean View Post
Frequencies below 10 hertz can of course be individually sampled, and the results manually added to the exported chart data for plotting in Excel or similar, if so desired.
To illustrate, the attached chart shows the default record constant directivity SPL response (with chamber resonances masked) plotted down to 1 hertz.
Kind regards,
David
www.hornresp.net
Old 19th December 2011, 11:17 AM   #2487
More than 2½ octaves from that horn.
Does this confirm that 4 horns are required to reproduce the 20Hz to 20kHz audio bandwidth?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th December 2011, 01:00 PM   #2488
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
No.
-Bjørn
Old 19th December 2011, 03:57 PM   #2489
Zero D is offline Zero D  United Kingdom
Default Help File
@ David McBean
Hi, thanks for the new HF etc, & glad i was able to offer some nudging
Unfortunately for some reason on trying to run it, i get this error ?
Old 20th December 2011, 01:32 AM   #2490
Mark Kravchenko
[QUOTE]More than 2½ octaves from that horn.
Does this confirm that 4 horns are required to reproduce the 20Hz to 20kHz audio bandwidth? [QUOTE]
I have a job where I'm doing it with three horns. And if you can cut down the low end to about 80 hz you can pull it off with two horns.
Mark
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Copyright ©1999-2017 diyAudio
