Hornresp - Page 241 - diyAudio
Old 5th November 2011, 04:58 PM   #2401
Zero D is offline Zero D  United Kingdom
Originally Posted by David McBean
While not wishing to put a dampener on your endeavours,
You havn't
I suspect that what you are trying to do, cannot be done, unfortunately... :-(.
I think you might be right with the limited specs of the quoted driver anyway. Maybe with a bit more data with other drivers ? Anyway no harm in trying, or preventing the creative processes from flowing I myself have found, & noticed in others over the years, that often interesting & useful things etc can/do/have come from thinking out of the box, and/or laterally etc as well as logically, no matter how crazy etc it appears at the time ! The downside is it "can" attract negative comments etc from "some" people but it's wise to ignore them
Not sure that I understand :-).
I was reffering to the eight character limitation in HR. But as you say,
don’t worry, as the rounded value of 2.08E-04 will be close enough.
That's good to know
Exactly - now you've got it :-).
Better late than never
Sometimes though, ignorance can be bliss :-).
Yeah, sometimes
Old 6th November 2011, 11:17 AM   #2402
Hi David, I'm not sure if anyone else has mentioned any problems with this but the window for Particle Velocity appears around 2/3 size of the main Hornresp window and unresizable.
The graph and controls are partially obscured and I can't alter the window to properly see the results.
I'm running on XP SP3 at 1920x1080 if that's any help!
Old 7th November 2011, 05:34 AM   #2403
witasso is offline witasso  Poland
Dear Mr. McBean:
Is there any possibility to have the option of writing the values of S and L in the scientific notation as is for the Cms value too?
Old 7th November 2011, 07:17 AM   #2404
Hi chucky12,
Thanks for the feedback - you are the first person to report this problem. The Particle Velocity form should display as shown in the attachment, and be just slightly smaller that the main Hornresp form. It cannot be resized.
I run XP also. I tried increasing my screen resolution to the maximum, but could not replicate the problem you are experiencing.
Do you still have the problem when you reduce your screen resolution?
Is the Particle Velocity form the only one that has the problem - is the Wavefront Simulator form okay, for example?
Would it be possible for you to post a screenprint of the incorrectly displayed form?
If anyone else has experienced a similar problem, could they please let me know.
Thanks and kind regards,
David
www.hornresp.net
Old 7th November 2011, 07:31 AM   #2405
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
XP SP3 1920x1080 is OK here.
Dan
Old 7th November 2011, 07:44 AM   #2406
Hi witasso,
Because Hornresp area and length values cannot be less than 0.00 or greater than 99999.99, and because of the eight-character input limit, there is little to be gained by expressing the S and L values in scientific notation. Also, the number of significant figures would be unnecessarily reduced. For example, an area of 12345.67 sq cm would be automatically rounded to 1.23E+04 or 12300.00.
Furthermore, it would complicate matters when inter-working with the Loudspeaker Wizard tool.
Kind regards,
David
www.hornresp.net
Old 7th November 2011, 07:47 AM   #2407
Excellent - thanks Dan.
It seems that chucky12 may have a problem unique to his computer.
Kind regards,
David
www.hornresp.net
Old 7th November 2011, 09:45 AM   #2408
Jmmlc is offline Jmmlc  France
R.I.P.
Hello David,
Too bad it cannot be done on S (and L) because one of the negative consequences is the impossibility to design a Le Cléac'h horn having an Fc lesser than 80Hz...
Best regards from Paris, France
Jean-Michel Le Cléac'h
Originally Posted by David McBean View Post
Hi witasso,
Kind regards,
David
Old 7th November 2011, 01:11 PM   #2409
GM is offline GM  United States
GM's Avatar
Mine's fine, but FWIW, this happened to me with the impulse response screen way back when and uninstalling HR and DLing/installing it again solved the problem.
Nice to know I'm not the only one with a weird XP machine, even this fresh install on a different computer has its quirks, though not all the same as before............ [SP2, 1024x768]. FWIW, mine is an early multiple registered copy of XP rather than a retail single user copy.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th November 2011, 04:42 PM   #2410
Re - Inputting TSP etc as scientific characters.
In ALL the hundreds & hundreds of drivers specs i've looked at over the years, i can't recall ANY manufacturer listing them in such terms ! So for people to then have to convert them to input into HR etc, is & would be IMO, an inconvience.
I do however take note of what Jmmlc said.
"If" at some point in the future, we could choose to input in either/or terms, then that would surely satisfy everybody I think i know what you're going to say though, & it begins with - It's not .........
Re - Particle Velocity
I'm using XP/SP2 & this is Exactly how it appears to me.
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Copyright ©1999-2017 diyAudio
