#2381 | |
As John Sheerin stated, "Compression drivers have mechanical parameters just like any transducer", but to calculate T/S parameters would require more detail than voice coil size, impedance, inductance and magnetic strength. |
#2382 | |
#2383 |
Hi Chris,
All you really need to know are the exit area, exit angle and low frequency limit of the compression driver. If the exit angle is unknown then simply make an educated guess - it will be close enough. Procedure: 1. Use the Hornresp Horn Segment Wizard to determine the required horn given inputs S1, F12, AT and Fta. For the example shown I have assumed a 2" diameter driver exit area, an exit half-angle of 5 degrees, and a required horn cutoff frequency of 250 hertz. 2. Calculate the results for Ang = 4.0 x Pi and Eg = 0. By setting Eg to zero, a constant velocity driver is assumed - it doesn't matter what driver parameter values are used. 3. Export the exact axisymmetric profile and use the data to construct the horn. Kind regards, David
www.hornresp.net |
#2384 | |
See my post above. Kind regards, David
www.hornresp.net |
#2385 | |
I am going to use a JBL 2441. I think I have read somewhere that the exit angle is 10 degrees on most of the JBL drivers, so this shouldn't be to difficult. |
#2386 | |
Maybe that's the next step for this software. |
#2387 |
Passive crossovers with a compression driver is not the easiest task, I have read...that's why I go active, though not a walk in the park that either..
#2388 |
@ David Mcbean
Hi, thanks i will reply to your posts soon.
#2389 | |
Sorry, it's not going to happen :-). My interest lies with the performance of the loudspeaker itself, not with how the signal is processed prior to reaching the driver. Kind regards, David
www.hornresp.net |
#2390 |
OK, but without such a simulation it remains unclear (without lots of experimenting) how horn loudspeakers respond to passive crossovers. I'm not sure they respond in the same way that direct radiators respond, for example. I also don't think I can model horns in other kinds of software that do allow for the effects of a passive crossover and other filter elements.
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
