Hornresp - Page 238 - diyAudio
Old 1st November 2011, 05:34 AM   #2371
Hi Zero D,
Originally Posted by Zero D View Post
Cms is shown as for eg = 4.00E-04 What do they mean, & why can't we enter in m/N ?
Cms is given in units of metres per newton. Because the value is small, it is expressed in engineering notation (similar to scientific notation). A value of 4.00E-04 is the same as 4.00 * 10 ^ -4 or 4.00 / 10000 or 0.0004 m/N. Try entering 0.0004 into the Cms input box and see what happens.
Rms & Le arn't always quoted in driver TSP's, but i'm presuming these are auto calculated by HR ?
Just to clarify - Rms and Le are not Thiele-Small parameters, they are conventional electro-mechanical parameters. The values are not auto-calculated by Hornresp. If Le is not given in the driver's specifications, then set the value to 1.00 millihenry. It will be close enough for the purposes of the simulation. If Rms is not given, it can be derived using the Calculate Parameter tool.
I don't see anywhere to enter Xmax, so how is DD arrived at ?
From the SPL Response window, select the Maximum SPL tool and then enter the desired Pmax and Xmax values.
Also when clicking on some Data Entry Boxes i get popups for entering Vas & fs etc, & asking if other parameters are correct. I think it would be clearer/easier, for us to be able to have extra DEB's to enter these directly.
Sorry, it's not going to happen :-).
I've manged to modify your nice PDF, & highlighted in Yellow the text that was highlighted in Green in HR's Help File.
The secondary comments displayed in green in the Help file are shown in italics when printed out in hard copy form - as for the PDF file.
Kind regards,
David
www.hornresp.net
Old 1st November 2011, 11:47 AM   #2372
Default Correction
Just for the record - I should have said:
"Because the value is small, it is expressed in scientific notation (similar to engineering notation)."
0.0004 expressed in scientific notation is 4.00E-04
0.0004 expressed in engineering notation is 400.00E-06
Kind regards,
David
www.hornresp.net
Old 1st November 2011, 12:15 PM   #2373
sannax is offline sannax  Norway
Can anyone point me to how to calculate a horn using a compression driver, and how to eventually calculate the throat angle of the horn (using Rta?)? My apologies if it has been discussed earlier in the thread.
Thanks!
Old 1st November 2011, 12:44 PM   #2374
dirkwright's Avatar
Thanks!
It's not really possible, since there aren't T/S parameters for the drivers.
Old 1st November 2011, 01:11 PM   #2375
Ok, so what to do? How are people then able to calculate entry angel?
Old 1st November 2011, 02:18 PM   #2376
dirkwright's Avatar
Well, don't use Hornresp generally for that. At least I haven't seen it.
I think most people who use compression drivers just follow the manufacturer's or their own ideas on which horn to use with it. Obviously, a 2" compression driver needs a horn with a 2" round throat, and the lower cutoff is given by the manufacturer, so you've got the basics for a horn right there. You can basically choose the shape and dispersion angles as you feel you need. Some folks put a waveguide on them, but that requires experimentation I think.
For example, if you've got the hots for the B&C DCM50, which is a 2" midrange compression driver, then I'd just follow the manufacturer's guidelines for using it. They say that it's good down to 400Hz, but the curve they show looks better at 500Hz, so that's the horn you need. Whether it's a tractrix, exponential, or whatever, is up to you. Making a passive crossover for compression drivers is even more hairy....
Old 1st November 2011, 03:08 PM   #2377
Well, my plan is to make a LeCleach horn for a JBL 2" driver. I am certain that I have read about someone talking about the throat angle, have to search my computer. I am almost certain that Autotech makes horns on order with the right angle. I will ask in the Jmmlc thread.
Thanks!
Old 1st November 2011, 04:05 PM   #2378
Compression drivers have mechanical parameters just like any transducer. That means you can calculate T/S parameters for them if you want. However these parameters are not typically published. For some of the new JBL drivers, you can get a lot of the parameters from the data sheets published on the Audio Heritage website.
Old 1st November 2011, 05:44 PM   #2379
Is the throat exit angle of a compression driver stated in the manufacturer's datasheet?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st November 2011, 05:56 PM   #2380
dirkwright's Avatar
OK, here are the specs for the B&C DE10 1" compression driver. Is it possible to calculate T/S parameters from this data? I'm sorry I'm not expert enough to know how myself.
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright 1999-2017 diyAudio
