Hornresp
Hornresp
Old 14th October 2008, 09:38 AM   #211
Brett is offline Brett
Brett's Avatar
Originally posted by David McBean
Hi Brett,
Thanks for confirming that Hornresp now works with your new Vista operating system.
I continue to refine the code to make the operation of the VB3 and VB6 versions identical. The latest release is Product Number 2000-081014.
Kind regards,
David
David,
I'm really busy for a week, then away for a week, but I need to do some simulation work when I get back and will let you know if I have any issues. However, I'm confident there won't be, but I'll let you know in detail if I find anything amiss.
Cheers
Old 14th October 2008, 02:46 PM   #212
screamersusa is offline screamersusa  United States
I'm tearing my hair out so I have a few questions. V419
1) What hornresp shows and what the 9 cabinets I've built and test show do not agree. Horn resp shows a dip in response where I have peaks. I tweaked the amp impedence to get the post test to match the actual paper test. What am I doing wrong?
Does the tapped horn wizard include combined response?
When I calculate the results, is it combined or horn only?
2) How do I input compression into hornresp. I.E. I have a 15 inch driver and I want a 440 sq cm (roughly) hole that the driver fires into resulting in 2:1 compression. Or perhaps a V opening.
Example:
Freq Test cab horn resp
40 78db 95
45 92 98
55 104 101
60 95 98
70 104 96
90 78 97
105 95 100
120 95 92
140 98 98
Two suggestions.
1) I'm sure everyone has asked for more segments.
2) Ability to set the tapped horn wizard result window
to MAX spl (with a default setting you can set).
Possibly also the Phase and electrical impedence.
I found I got results more in line with what I needed by using max spl. The last test box tested about right compared to horn resp results with 300w using the max spl. Since I do LOUD shows
the max response is important.
Thanks.
Donations? To where do I send it? Nice program.
Old 14th October 2008, 04:38 PM   #213
Rademakers is offline Rademakers  Netherlands
There are quite some possibilities to consider, so I've written down some I can think of, you can eliminate some to narrow down the problem.
1) Possible options:
- You didn't simulate correctly (you didn't made what you were simulating).
- The measurement wasn't correct (this can include effects of the envirement on the measurement, i.e. standing waves).
- You're not using the latest version of Hornresp (some earlier versions contained errors for tapped horn simulation).
- The T/S-parameters of the simulated driver do mismatch the T/S-parameters of the measured driver by far.
- Hornresp is wrong.
The T/S-parameters given by manufacturers are usually measured after a pre- conditiong round (so the voice coil is getting warmed up). Higher power means an elevated temperature in the voice coil, which in turn changes the T/S-parameters. That's why it's better to do a 28,3 V/10 m measurement than a 2,83 V/ 1 m measurement (especially for PA).
2) Compression ratio in a tapped horn and offset horn is Sd / S2.
Regards Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 14th October 2008, 08:09 PM   #214
aznboi3644 is offline aznboi3644  United States
Does anyone know how to model a backloaded horn in Hornresp??
Old 14th October 2008, 10:45 PM   #215
Regards Johan
I actually re measured the physical cabinet and made corrections in horn resp. I then tried to make the physically modeled and tested measurements match in hornresp by throwing it off to no avail. Then it hit me... I had marked where I heard phase cancellations in my measurements. I checked the phase response and there was part of it. Would be nice if you could combine the output and optionally add in the phase error in the tapped horn window.
I did use the Danley 10m measurement method.
Thanks for the tips. The tapped horn wizard is sweet, maybe David will add more wizards..... maybe we should refer to him as the wizard.
Old 15th October 2008, 05:24 AM   #216
David McBean is offline David McBean  Australia
Hi aznboi3644,
Assuming that you are now using Version 20.00, have you read note 9 on page 16 of the Hornresp Help file?
Kind regards,
David
www.hornresp.net
Old 15th October 2008, 05:41 AM   #217
Hi Brett,
Many thanks, that would be really great!
Before you start your simulation work, could you please check that you are using the latest release, as I may find that I need to make further code changes between now and then :-).
Kind regards,
David
www.hornresp.net
Old 15th October 2008, 05:58 AM   #218
Hi screamersusa,
For a tapped horn, Hornresp calculates the SPL at a distance of one metre from the horn mouth. The outputs from both sides of the diaphragm are taken into account. Hope this answers your "combined response" question.
Kind regards,
David
www.hornresp.net
Old 15th October 2008, 10:42 PM   #219
Hi aznboi3644,
Kind regards,
David
I just downloaded it...its hard to keep up with all of the new versions lol.
You need to slow it down David lol
Thank you.
Old 17th October 2008, 02:35 PM   #220
MaVo is offline MaVo  Germany
Hi David,
in your help file for the system design function, you write that it designs an optimum system for the given frequency range and driver. Now, i observed that the frequency response often has these little and regular peaks, while handmade designs can have a flatter frequency response within the same size restrictions. Can you (or whoever knows better than me) explain what design criteria "optimal" refers to?
Hornresp v20 looks like a great improvement, i got random crashes on my amd/winxp system with v19 and before, especially while running other software in the background, which seem to have stopped now.
As allways, thanks for your awesome software.
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
