Hornresp - Page 216 - diyAudio
Old 17th August 2011, 05:27 PM   #2151
dirkwright's Avatar
Originally Posted by John Sheerin View Post
I have some information on my website about how sound waves propagate around horn bends. It might not be exactly what you're looking for, but it's a start.
Thanks. I'm not really looking to design a folded horn but I find the subject interesting anyway. It would be awesome if David incorporated something like that into Hornresp, though as it stands now it is an incredible service to us to provide such a powerful software package for free. We didn't have this kind of stuff back when I last designed a horn in 1991. I'm really grateful for David's contribution.
Old 17th August 2011, 06:20 PM   #2152
dirkwright's Avatar
Very interesting article! thank you! Your animations are fascinating. The sound just seems to squish around the corners, sometimes getting confused reflections or just disappearing. It seems to me that folded corners are low pass acoustical filters that add a lot of distortion, but that's just a guess on my part.
http://www.jhsaudio.com/waves.html
Old 17th August 2011, 08:10 PM   #2153
Thanks. Actually bends would probably remove distortion. If they're an acoustical low pass filters, they would attenuate harmonics which are what distortion is. They can definitely have a negative effect on frequency response and polar response at higher frequencies though.
Old 18th August 2011, 07:45 AM   #2154
Question to David: would it be possible to see an option to choose a frequency response curve between "Acoustic power" and "Acoustic pressure" like Akabak? Thank.
Old 18th August 2011, 08:44 AM   #2155
Originally Posted by tb46 View Post
You've got mail.
Thanks Oliver, I will let you know what I find.
Kind regards,
David
www.hornresp.net
Old 18th August 2011, 08:56 AM   #2156
Hi julienb34,
Select the Tools > Directivity > Response... menu command to show the pressure response.
Note that the tool only applies to finite single-segment non-negative flare horns.
You will find that the results are probably different to those generated by AkAbak, which uses a relatively simple directivity model compared to Hornresp.
Kind regards,
David
www.hornresp.net
Old 18th August 2011, 09:00 AM   #2157
Originally Posted by dirkwright View Post
It would be awesome if David incorporated something like that into Hornresp.
Hi dirkwright,
Sorry, it's not going to happen... :-).
Kind regards,
David
www.hornresp.net
Old 18th August 2011, 12:05 PM   #2158
Default Bug Fix
Hi Oliver,
The bug you found has now hopefully been fixed.
Could you please confirm that your Hornresp_good.dat file converts correctly when opened using Product Number 2870-110818.
Thanks again for all your help!
Kind regards,
David
www.hornresp.net
Old 18th August 2011, 12:44 PM   #2159
the download site still says 110816 but the download works with 110818 thanks david
Ted
Old 18th August 2011, 03:48 PM   #2160
tb46 is offline tb46  United States
Default Bug Fix - Post #2158
Hi David,
The new version downloaded and updated fine with the correct number. Everything I have tried sofar has worked just fine.
Thank you again for your remarkable effort.
Oliver
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Copyright 1999-2017 diyAudio
