Hornresp
Hornresp
Old 16th August 2011, 06:11 AM   #2131
David McBean is offline David McBean  Australia
Default Bug Fix
Hi Everyone,
I found a bug in the Y-axis scaling of the new charts when plotting certain small values. The first screenprint shows the incorrect scaling caused by the bug (insufficient resolution giving multiple instances of the same value). The second screenprint shows the correct scaling when the bug is removed.
The latest release is Product Number 2870-110816.
Kind regards,
David
www.hornresp.net
Old 16th August 2011, 06:36 AM   #2132
Brian Steele is online now Brian Steele  Grenada
These new versions are coming out so quickly - perhaps it's time for an auto-update feature for HornResp
Old 16th August 2011, 06:47 AM   #2133
Hi dirkwright,
Originally Posted by dirkwright View Post
Why doesn't the schematic show the horn ending in a 90 degree flare?
Because with your design, the mouth is severely truncated, as indicated earlier :-).
Using your values of S1 = 167.80 sq cm and F12 = 60.04 Hz, a fully formed tractrix horn would have a length L12 of 202.31 cm and a mouth area S2 of 26123.15 sq cm. See the attached screenprint.
Kind regards,
David
www.hornresp.net
Old 16th August 2011, 07:03 AM   #2134
Originally Posted by mwmkravchenko View Post
Uni is a horn where you set up Hornresp to make a horn having two parallel side walls and the rest changes.
Hi Mark,
Just to clarify - the 'Uni' width flare option uniformly transforms the horn rectangular cross-section area aspect ratio from the throat to the mouth. The horn will have two parallel side walls only if the S1 and S2 height values are specified to be the same.
Kind regards,
David
www.hornresp.net
Old 16th August 2011, 07:43 AM   #2135
Are you saying that tractrix are only good if they are full sized horns? Why would that be the case?
Hi dirkwright,
The throat acoustical impedance of a fully formed tractrix horn will be "smoother" than that of a truncated one because of the better matching conditions at the horn mouth - there is less of a discontinuity as the wavefronts leave the horn.
The first screenprint shows the predicted normalised throat impedance of your design (radiating into 1 Pi space). The second screenprint shows the predicted normalised throat impedance of a full-mouth 90 degree tractrix horn having the same S1 and F12 values as your design (radiating into 1 Pi space).
Kind regards,
David
www.hornresp.net
Old 16th August 2011, 07:50 AM   #2136
I don't understand what you mean by parallel and series connected drivers. Do you mean electrically or acoustically?
Hi dirkwright,
Electrically.
Kind regards,
David
www.hornresp.net
Old 16th August 2011, 09:43 AM   #2137
Kenel is offline Kenel  France
Hi everyone,
first post and maybe not at the right place?
After a build of 2 Folded Horns with 15'' drivers designed with HORNRESP (which sound great & thanks so much David...), I hope some of you can help me to correct my new design of 18'' Rear Loaded Horn.
Actually it's a bit hard to find explanations on using Hornresp to calculate this kind of horns and as I'm planing to build 4 bins like that - the budget makes me wonder if everything is right... That's why I'm posting this here... Let me know if I should create a new post?
Any comment will be highly appreciated
HORNRESP PARAMETERS (for a stack of 4 bins in parallel / PD186 drivers)
WHAT IT LOOKS LIKE
Many thanks
Olive
Old 16th August 2011, 09:53 AM   #2138
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Hornresp
Welcome to diyAudio Olive! I think you have chosen the right place .
edit: woops, the post didn't approve and in the meantime I went and got dinner. Welcome again!
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 16th August 2011, 12:14 PM   #2139
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Hi dirkwright,
Kind regards,
David
Thanks. Two meters is way too long for a straight horn in my house! Is it possible to simulate a folded horn in your program? I seem to be stuck here with needing a horn that goes up to 500Hz and as low as possible. I guess 100Hz is much more reasonable for the lower cutoff. A 1/2 size hyp-ex is 1 meter long.
Old 16th August 2011, 03:11 PM   #2140
dirkwright's Avatar
Originally Posted by Kolbrek View Post
Regarding reactance anulling, the idea is to make the negative reactance of the rear chamber equal to the positive mass reactance of the horn. This way they largely cancel, and the load seen by the driver is mainly resistive in the working range. It is first described by A.L. Thuras in US patent # 2037185.
Bjørn
OK, what is the advantage of having the driver see a resistive load? Does it increase efficiency or something? Do direct radiator type of loudspeakers see a resistive load in the free air? Why can't the resonant impedance peak be removed by a notch filter? I have not read the patent but I can do that today.
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
