Hornresp
Hornresp
Old 1st August 2011, 08:42 PM   #2061
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Very much appreciated Don
By the way the way you describe was the way I was doing it.
Less the "Turn off Draw Opaque in Paint". That I did not know.
Mark
www.kravchenko-audio.com
Old 2nd August 2011, 10:48 AM   #2062
R.I.P.
Originally Posted by Don Hills View Post
Make a second copy of the 3 Hornresp files in a different folder. (Hornresp.exe, Hornresp.dat, msvbm60.dll) You can then start both copies.
You will need to use import/export to keep the two copies of hornresp.dat in sync. Or you can make any changes you want to save in one copy, then exit both and copy the hornresp.dat from one to the other. Be careful and keep backups, sooner or later you will mess it up...
One thing I often do for comparing graphs in Hornresp is to use Paint, the basic image editor included in Windows.
- Produce a graph in Hornresp.
- Capture it to clipboard (Alt-PrintScreen).
- Start Paint, paste (Ctrl-C).
- Produce another graph in Hornresp.
- Turn off Draw Opaque in Paint (Image --> Draw Opaque, untick.)
- Paste (Ctrl-c)
Could this be written into a little DOS routine?
How could that DOS program be called up by clicking on a windows icon " second Hornresp"
regards Andrew T.
Old 2nd August 2011, 01:20 PM   #2063
tb46 is offline tb46  United States
Nice tip by Don. If you put it into a program make shure you use "CTRL-V" for pasting (CTRL-C is for copying).
You also can do this multiple times, so you can compare a number of e.g.: curves.
Oliver
Old 2nd August 2011, 02:39 PM   #2064
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
Originally Posted by mwmkravchenko View Post
Can you download off of the AES site?
Yes, if you have e-library access you can download as much as you want. If you are not a member, you can purchase the articles one by one. If you need more than a few articles, it makes sense to pay for the e-lib access.
If some correlation between sound pressure and air particle velocity can be made, maybe we will have a useful tool in the design of horns and their physical dimensional aspect ratios. All these things add up to a better design if attention is paid to the correct details.
The correlation between particle velocity and pressure is impedance. Acoustic impedance is defined as pressure divided by (particle velocity times area). Note however that impedance is only defined as long as everything is linear.
Bjørn
Old 2nd August 2011, 02:56 PM   #2065
GM is offline GM  United States
GM's Avatar
I hope that first off I can get an anemometer that will behave.
Second a proper high spl mike that will behave.
Seems like using vehicle manifold MAP sensors would be ideal for these types of measurements.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 2nd August 2011, 03:23 PM   #2066
Pano is online now Pano  United States
Pano's Avatar
Hornresp
I can highly recommend MWSnap3 for screen captures. Fast, free, easy to use and makes great captures in a small file size. I use it every day.
Old 2nd August 2011, 05:53 PM   #2067
Mark Kravchenko
Hornresp
Bjørn
Yep. What I meant is not only a theoretical understanding but the actual impedance versus change in horn aspect ratio or even horn total path surface area. Better stronger faster is what I'm after.
It seems that both things can make quite a difference in the outcome of a horns success.
GM
I think I have an even cheaper alternative.
Measurement specialties make some pretty inexpensive pressure transducers. They have to be able to measure very low pressures actually. And I am putting together an accelerometer to make insitu X-max measurements.
Mark
Old 2nd August 2011, 06:01 PM   #2068
jbell is offline jbell  United States
WAY off topic.... (apology)
Mark:
what organ is that on your computer background? I love the wood stop pulls vs something like the wannamaker.
Old 2nd August 2011, 06:03 PM   #2069
Mark Kravchenko
Hornresp
Weingarten Basilica.
First ever remote console tracker organ. A beauty to behold as well as listen to.
Mark
Old 2nd August 2011, 06:53 PM   #2070
Mark Kravchenko
Hornresp
Actually don't like the sound of the Wannamaker much.
Mark
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
