Hornresp
Hornresp
Old 16th July 2011, 02:49 PM   #2001
GM is offline GM  United States
GM's Avatar
Using the mean distance [acoustic center] of the driver line has proven close enough to actual measurements using MJK's MathCad software, so I see no reason why HR would be any different.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th July 2011, 03:01 PM   #2002
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Originally Posted by blo06 View Post
Hi Everyone,
I'm beginning with Hornresp, trying different things.
When simulating a Bass Reflex and comparing the result with WinISD's (to be sure I'm doing ok), I don't get the same response... Could you tell me why ?
I model the same box with the same vent and get two different Helmoltz freq and two different response curves...
In HR, I did it with the Loudspeaker Wizard (wonderful feature by the way !!)
Perhaps all of this is already explain in this tread, but there's # 2000 messages ! If so tell me where !
Regards.
I guess that what you are missing is that hornresp initially shows the output from the driver, without the output from the port.
To see the overall system response you need to select the combined response from the tools menu in the SPL window.
Old 16th July 2011, 06:28 PM   #2003
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Originally Posted by mashaffer View Post
What I am looking at is a quarter wave pipe (TL) with several identical drivers distributed along a portion of the pipe, not for smoothing necessarily but for convenience sake. I realize that HR can not simulate this directly (nor would it be reasonable to rewrite it to handle it) but what I am wondering is if one could not get a close enough approximation of the total response by simulating each position and averaging the results.
You've stuck an idea in my head:
What if Hornresp could crunch the numbers of multiple records? That is to say that if you created a file for each position along the path where a driver is located. It would also be interesting if you could use another mode of the multiple record technique for comparison. I think it would a need a check box to indicate if you wanted to sum or compare them and a row of buttons to load files that would allow you to also pick a color for the graph output...
Dan
Old 17th July 2011, 02:04 PM   #2004
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by NEO Dan View Post
...You've stuck an idea in my head:
What if Hornresp could crunch the numbers of multiple records? ...
Why not DIY. ..There are endless use if taking advantage of HR's export files.
Here is an example:
b
Old 17th July 2011, 05:50 PM   #2005
NEO Dan's Avatar
Originally Posted by bjorno View Post
Why not DIY.
Hi bjorno,
That's quite the undertaking, but I do wonder if hornresp could do a better job than HOLM? I was thinkning of this as a logical alternative to giving Hornresp a workover to make it aware of multiple driver locations in one record.
Dan
Old 17th July 2011, 06:58 PM   #2006
blo06 is offline blo06  France
Hi Xoc1,
I'm taking about the combined response. It doesn't look like the WinISD's.
For the close box, it's close but not the same, for the BR it's sometimes far away, specially for the low part.
Regards.
Old 18th July 2011, 06:48 AM   #2007
David McBean is offline David McBean  Australia
I'm taking about the combined response. It doesn't look like the WinISD's. For the close box, it's close but not the same, for the BR it's sometimes far away, specially for the low part.
Hi blo06,
Can you please post a screenprint of your Hornresp input parameters window, and also provide details of the WinISD Driver, Box and Vent values you are using for the purposes of the comparison. Thanks.
Kind regards,
David
www.hornresp.net
Old 18th July 2011, 08:20 AM   #2008
Originally Posted by David McBean View Post
Hi blo06,
Kind regards,
David
Hi David,
here they are.
Regards.
Old 18th July 2011, 09:01 AM   #2009
Xoc1's Avatar
blo06
Your AP figure is incorrect.
The AP Parameter is the cross sectional area of the port.
For a 10.2cm diameter round port this would be radius squared X pi = 81.71 sq cm.
Old 18th July 2011, 09:47 AM   #2010
blo06
I saw that too but more important is that the T/S parameters are way off.
Reason for this is probably from the advertised Cms value that is not consistent compared to other driver data.
b
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
