Hornresp
Hornresp
Old 25th May 2011, 04:40 PM   #1921
djn is offline djn  United States
djn's Avatar
Has anyone modeled Just he top of the Altec A7(825) cab. The ones that people cut down and just use the horn section? I just got a pair and for the life of me, I can't figure out HR. I can cut, weld, design....but I am NOT good with programs.
Old 25th May 2011, 05:12 PM   #1922
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Originally Posted by Jmmlc View Post
Hello David,
Could you add to Hornresp some controls for the coffee machine?
Best regards from Paris, France
Jean-Michel Le Cléac'h
Ca va etre tres drole observer ma mr.coffee travailler avec une scie electrique!
I think I might be able to figure out a sketchup plugin, I'll post something if I do.
Old 25th May 2011, 05:34 PM   #1923
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Haha, was that a French roast?
Dan
Old 25th May 2011, 08:42 PM   #1924
revintage is offline revintage
djn,
I have done the 828 together with 416-8B. Not a pretty sight! What driver do you have?
Old 25th May 2011, 10:00 PM   #1925
GM is offline GM  United States
GM's Avatar
I simmed the compression loaded ones I use to do in MJK's original FLH WS to proof its overall accuracy. It has maybe a bit too much built-in acoustic smoothing though for some of the folks here though. I'm busy with house repairs ATM, but as time permits I'll load them into HR to see if they look as ugly as Lars indicates. For sure, me and the folks I did them for thought they sounded pretty good at the time [~1968-1975].
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th May 2011, 10:19 PM   #1926
djn's Avatar
Originally Posted by revintage View Post
djn,
"not a pretty sight" How so? I will be using the Lambda TD15x drivres. interestingly....the T/S of the TD15x is VERY VERY similar to the 416.
GM
Thanks GM, much appreciated. I also have 4 really good subs to fill in the bottom end.
I will be using the red Edgarhorn and Heil in this pic on these cabs. I am moving to a smaller place and the big scoops are too big for my new room.
Old 25th May 2011, 11:42 PM   #1927
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Yes that is the way to go. but in my Excel, I get tiresome questions in two steps.
So copy and paste isn´t to bad.
Eventually not so much to discuss the result is the same.
Any one found a working, easy to use, Excel to CAD-program converter?
I recall there is a script for SolidWorks called Points Import or something like that.
Hear the real thing!
Old 26th May 2011, 06:36 AM   #1928
Hey GM,
What, compression? Do we mean the same cabinet? Didn´t everything sound great for a couple of years after Woodstock? Yes, it is a joke so don´t mind! I for some reason liked the dreadful production Klipshorns.
djn,
About not a pretty sight they aren´t! Needs smaller box other porting and maybe another flare in the horn.
OK, here is what comes out of HR. All dimensions aren´t exact but good enough. On-axis is acceptable.
There is an interesting article somewhere about Exemplar.
Old 26th May 2011, 06:47 AM   #1929
David McBean is offline David McBean  Australia
Hello David,
Hi Jean-Michel,
That's a great idea - after several hours simulating on Hornresp, most users are probably ready for a cup of coffee :-).
I will add it to the wish list... :-).
Kind regards,
David
www.hornresp.net
Old 26th May 2011, 09:44 AM   #1930
About VOTT, tune it to ca 40Hz. With 1,8cm baffle thickness it will be something like 200cm2.
Lambda TD15x
djn,
where are the T/S parameters? They are not AE´s site. This is all there is:
FS: 23.2Hz
Qts: 0.28
Vas: 467L
Estimated the other values in course sim and I guess it is better to check the drivers from Great Plains. The main reason is TD15x´s high cone mass.
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
