Hornresp
Hornresp
Old 19th May 2011, 10:01 AM   #1891
David McBean is offline David McBean  Australia
Originally Posted by Kolbrek View Post
Here's a drawing from the Quadratic Waveguide whitepaper by Hughes, showing how a radial horn is defined.
Thanks Bjørn, now I understand :-).
Kind regards,
David
www.hornresp.net
Old 19th May 2011, 10:06 AM   #1892
revintage is offline revintage
David,
To bad it wasn´t possible.
Bjørn,
Thanks for showing my (hard to understand)text in pictures.
Old 19th May 2011, 10:25 AM   #1893
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
Originally Posted by revintage View Post
This is tractrix spreadsheet I found. I haven´t analyzed it though.
The spreadsheet doesn't have any calculation of the basic areas, it just takes in distance, radius and area. So I guess you could take the exported distance and radius values from Hornresp, and put them into the spreadsheet to get the radial horn dimensions.
Bjørn
Old 19th May 2011, 10:36 AM   #1894
Noticed they lacked but you can take the data either from Hornresp or use the original equations(as I do for Exp, Kw(S) or Tx. Haven´t tried to export the text-files from Hornresp. LC must be taken from Hornresp.
Just for fun, this an (not so typical) example that I still haven´t finished: An Altec 511 Exp rebuilt for taking a 2" driver with help of a JBL 2328 adapter.
Old 20th May 2011, 11:28 AM   #1895
Sabbelbacke is offline Sabbelbacke  Germany
Hy everyone. I am having a hard time fiddling out some correct Driver paramaters of "typical" PA-High Frequency drivers in order to simulate some horns from 1-20kHz. Simply measuring the TSP gives strange results...
Does anyone have some reliable real-world driver-parameters as a starting point for one of "the usual" 1", 1.4" or 1.5" drivers (B&C, BMS, 18S... not really important, it´s more an academic issue - we want give the CNC something "meaningful" to do and thought of starting building hornflares...)
Old 23rd May 2011, 09:24 AM   #1896
Jmmlc is offline Jmmlc  France
R.I.P.
Hello,
For a design not intended to be adapted to a special loudspeaker, you can set Eg = 0.
Doing this you'll have a constant velocity source replacing the loudspeaker.
No more need to introduce T&S parameters for the driver...
Best regards from Paris, France
Jean-Michel Le Cléac'h
Old 23rd May 2011, 02:50 PM   #1897
zerowaf is offline zerowaf  Croatia
Hi everybody!
Have downloaded hornresp zip file, but I'm unsure something is wrong.
Zip have GOM player file I can not initiate 'cause of missing codec - but can not find codec on the link provided. Saiz the file is corrupted.
Lars (Revintage) has give me notepad, but seems to be I'm unable to paste it into hornresp.
Would someone be so kind to tell me what I am doing wrong way?
Thank's!
Old 23rd May 2011, 02:59 PM   #1898
I am not sure if I understand correctly, but it seems you are trying to open a ZIP File with a media player?
Take Winrar (or 7Zip or Winzip or something else that´s capable of handling a ZIP File).
You need no codec. Codecs belong to the video/audio domain and are used to play music or films oder videoclips...
Old 23rd May 2011, 03:14 PM   #1899
Understand why you think so - my silly english , but not.
When I unzip hornresp there is also GOM file among hornrespons files. That file can not open.
I can open hornrespons and seems to me like it is working. But I can not (or don't know how!) paste notepad that i got into hornresp.
Old 23rd May 2011, 03:24 PM   #1900
witasso is offline witasso  Poland
You have GOM player as default videoplayer and files with extension .dat setted to be opened with this soft. This .dat file is not to be managed outside of hornresp and is not a video data, is the database of your projects.
To use the notepad file save it into Import folder in the honrnresp directory. Run hornresp and use the option File -> Import -> Hornresp Record.
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Copyright ©1999-2017 diyAudio
