#1881 | |
When exporting the horn data, simply set the Width Flare to 'Con'. Kind regards, David
www.hornresp.net |
#1882 | ||
Hi kahvis,
Kind regards, David
www.hornresp.net |
#1883 | |
Thanks for helping |
#1884 | |
Correct. To simulate the 1. tapped horn configuration, set L12 = 0,01 cm. Kind regards, David
www.hornresp.net |
#1885 | |
This should be to much of a approximation. This as length will be another due to the area will be larger for the same length at 0 degrees as the mouth is curved. The sides of the Con will be too long. If we use a flare like tractrix where design is made from the mouth and backwards to the point where it is square, a radial will work. After that adding a square to round section to the driver. This should be done to give a smooth transition to the radial section. Otherwise a JBL 2328 could be added. I don´t thin it will be good idea to place the driver directly to the radial section. Altec 511 is a rough example of an old exponential design. These are my thougths(guesses) about it. This was hard to explain in English. Hope it is understandable. |
#1886 | |
. Have to give it some more thought. Probably the area should be the same but the sides shorter?For me it "feels" right that the length is the same at every angle. Last edited by revintage; 18th May 2011 at 02:26 PM. |
#1887 | |
There is no reason why the mouth fronts of the top and bottom panels of the radial horn specifed by Hornresp couldn't be curved or 'rounded' and the mouth sides shortened accordingly, if so desired. Either way, the horn planar area expansion rate will still be correct. The attachments refer to an exponential horn having S1 = 25 sq cm, S2 = 2700 sq cm and L12 = 50 cm. The flare profiles shown in attachment 2 assume S1 = 5H x 5W and S2 = 30H x 90W. If you want curved wavefronts to expand at an exponential rate however, then that is a different story :-). Kind regards, David
www.hornresp.net |
#1888 |
Hi David,
The question was how to get a profile that is the same from side to side in a Con horn. Is this a feature I have missed? What I get is a varying profile that is to long(stretched) at the sides. It is not a curved wavefront I want, it is a curved(radial) hornfront making the profile the same from side to side. This also mean the area is measured radial in the horn. It is, as I understood it right, how a radialhorn is defined. It might though be acoustically wrong. This is tractrix spreadsheet I found. I haven´t analyzed it though. Last edited by revintage; 19th May 2011 at 08:54 AM. |
#1889 |
Here's a drawing from the Quadratic Waveguide whitepaper by Hughes, showing how a radial horn is defined.
Bjørn |
#1890 |
Hi Lars,
In that case, Hornresp will not give you what you want :-). I misinterpreted your definition of radial horn - my mistake, sorry. Kind regards, David
www.hornresp.net |
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
