Hornresp
Hornresp
Old 23rd April 2011, 08:04 AM   #1851
reemoo is offline reemoo  United States
David,
You are amazing! Just what I wished for.
Old 23rd April 2011, 08:10 AM   #1852
David McBean is offline David McBean  Australia
Hi reemoo,
Some wishes do come true then, it would seem :-).
Kind regards,
David
www.hornresp.net
Old 23rd April 2011, 02:05 PM   #1853
R.I.P.
It is Easter anniversary, miracles can happen!
regards Andrew T.
Old 27th April 2011, 07:49 AM   #1854
Default Hornresp Update
Hi Everyone,
A check box has now been added to the Hornresp polar map to enable results to be shown normalised to the on-axis response, if required.
My thanks to John Sheerin for raising the issue.
Kind regards,
David
www.hornresp.net
Old 27th April 2011, 09:55 AM   #1855
revintage is offline revintage
Hello David,
Many suggestions now. But couldn´t you make the "checked pattern(?)" in the printouts with thicker lines? Can´t see them in my printouts. Have tried several printers.
Old 27th April 2011, 02:47 PM   #1856
Jmmlc is offline Jmmlc  France
R.I.P.
Hello David,
The on-axis normalization button is a great tool!
Here attached a comparison between a Le Cleac'h horn and an OS waveguide of the same dimension.
Doesn't need any coment...
Best regards from Paris, France
Jean-Michel Le Cléac'h
Originally Posted by David McBean View Post
Hi Everyone,
Kind regards,
David
Old 27th April 2011, 03:21 PM   #1857
John Sheerin is offline John Sheerin  United States
That's a bit misleading - you're comparing an OS horn with no round over at the mouth to your flair which does have a round over. Of course the polar map will be smoother for the LC flair in this case, but if you actually build an OS flair with a sharp corner at the mouth you are missing the point. What is obvious is that the OS even without a proper mouth termination has pretty much constant directivity within its usable bandwith while the LC flair has continuously increasing directivity.
Old 27th April 2011, 03:52 PM   #1858
R.I.P.
posts1854 and 1856.
Please tell us how to read what those pics are telling us.
And tell us, when we need to create them and how to create them.
regards Andrew T.
Old 27th April 2011, 04:16 PM   #1859
R.I.P.
Hello John,
I agree that's a little bit misleading so the comparison between Hornresp results and real mesurements should be more interesting:
Real measurements for a Le Cléac'h horn:
http://www.horns.pl/images/horns/jmlc200t.jpg
polar: http://www.diyaudio.com/forums/attac...dir_matlab.png
real measurement for an OS waveguide having the recommanded round over at the mouth
http://www.diysoundgroup.com/images/large/OSWG_12.jpg
polar: http://www.diysoundgroup.com/images/large/OSWG_Sono.jpg
No comment again...
Old 28th April 2011, 06:01 AM   #1860
Hi Lars,
Just to clarify - by "checked pattern(?)" do you mean the chart gridlines?
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
