Hornresp
Hornresp
Old 19th April 2011, 05:20 AM   #1841
David McBean is offline David McBean  Australia
Originally Posted by kahvis View Post
All the areas and the lengths are correct, but is there some problems in the shape?
Hi kahvis,
The Hornresp-predicted results for your proposed design should be okay. The two 90 degree bends are unlikely to significantly affect the 30-120 Hz response.
Kind regards,
David
www.hornresp.net
Old 19th April 2011, 05:28 AM   #1842
Originally Posted by brsanko View Post
So what effects generally would this configuration have.
Hi brsanko,
Your guess is as good as mine... :-).
My "gut feeling" is that the overall combined response performance should not be unduly compromised, but I am not really sure.
Perhaps someone has built such a system, and can comment more authoritatively.
Kind regards,
David
www.hornresp.net
Old 20th April 2011, 01:00 AM   #1843
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
Okay I know this is a tall order but would it be possible to integrate a simple crossover effect into the response graph? Like just click an option that says lowpass, high pass or band pass, and either enter a frequency or use a slider and then maybe a choice between 1st 2nd and 3rd order? Just a thought, I'm doing it in my head fairly easily but it would make it easier to see how say a tapped horn and a rear loaded horn would blend together. I know I"ve made suggestions before and you explained why it wasn't with in the scope of the program and then implemented it six month later anyway so I'll be keeping my fingers crossed. Thanks David you rock!
PASSIONN
Old 20th April 2011, 06:48 AM   #1844
Would it be possible to integrate a simple crossover effect into the response graph?
Hi brsanko,
Sorry, it's not going to happen :-).
Kind regards,
David
www.hornresp.net
Old 20th April 2011, 07:16 AM   #1845
kahvis is offline kahvis  Finland
Thanks for the reply.
I have another question about tapped horn. How this kind of tapped horn can be simulated? What about middle fold area/driver's sd ration?
Old 20th April 2011, 08:00 AM   #1846
Hi kahvis,
Specify two drivers using the Driver Arrangement tool.
Consider total areas (ie. add the two separate mouth areas together for the purposes of the simulation).
The Sd / S2 compression ratio figure given by Hornresp automatically takes multiple drivers into account.
Kind regards,
David
www.hornresp.net
Old 20th April 2011, 08:16 AM   #1847
Originally Posted by David McBean View Post
Hi kahvis,
Horn segment's areas in the hornresp is all the same, like picture?
Is the simulation result same for these two tapped horns? Only difference in cabinet size and pressure in s2?
Segment areas are same for whole way.
Old 20th April 2011, 08:23 AM   #1848
Hi kahvis,
The results will not be the same because of the difference in areas / volumes.
Kind regards,
David
www.hornresp.net
Old 22nd April 2011, 07:38 AM   #1849
Default Hornresp Update
Hi Everyone,
The Hornresp export horn data tool now has a multiple petal option - 3 to 20 sides can be specified. My thanks to Lars (revintage) for suggesting the feature.
Product Number 2840-110422 refers.
Kind regards,
David
www.hornresp.net
Old 22nd April 2011, 10:35 AM   #1850
Ivo is offline Ivo  Netherlands
Petal horn feature! Great!
We want to be happy, bold and free
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
