Hornresp
Hornresp
Old 8th February 2011, 05:28 PM   #1631
GM is offline GM  United States
GM's Avatar
Greets!
DMB,
Got a strange one here with 2830-110124. Records 2 thru 10 makes the LW active, but returns a run-time error when clicked on. Ditto when I add a record using them. Everything seems fine from 11 upward in a sampling.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 8th February 2011, 06:12 PM   #1632
IslandPink is offline IslandPink  United Kingdom
Default Saving/posting plots
Thanks all for the advice and particularly to Brian Steele who provided the neatest solution .
MJ
Old 8th February 2011, 07:21 PM   #1633
GM's Avatar
Originally Posted by Sabbelbacke View Post
Meanwhile, please use this adress.........
Thanks!
OK, deleted HR and did a new install, but still get the run-time error.
GM
Old 9th February 2011, 05:40 AM   #1634
David McBean is offline David McBean  Australia
Originally Posted by revboden View Post
the file at Hornresp seems to be broken.
Hi revboden,
Thanks to Sabbelbacke, everything appears to be back to normal again :-).
Kind regards,
David
www.hornresp.net
Old 9th February 2011, 06:26 AM   #1635
Hi GM,
This certainly is an interesting one.
Indications are that perhaps records 2 through 10 have been corrupted in some way. If you care to send me a copy of part of your Hornresp.dat data file, I would be happy to investigate further.
Double-click on the Hornresp.dat filename in Windows Explorer to open the file in Notepad, then copy and paste the first dozen or so records into a new file and forward to me at dmcbean@bigpond.com. You are welcome to send a copy of the whole file if you prefer - I realise that it is rather large :-).
Kind regards,
David
www.hornresp.net
Old 9th February 2011, 09:59 AM   #1636
Brian Steele is offline Brian Steele  Grenada
Default Throat vent expansion
Hi David:
Just a quick one - HornResp allows the user to set the type of expansion (Conical, Exponential or Parabolic) for the various segments of the horn. Can this be extended to include the throat vent too? At the moment it looks like only Conical expansion is supported (there's no option to change it to anything else).
See attached for an example, where the vent expansion from 55 cm^2 (Apt1) to 135cm^2 (at S1) is assumed to be conical.
Old 9th February 2011, 02:40 PM   #1637
GM's Avatar
Greets!
Thanks!
YGM
GM
Old 10th February 2011, 05:48 AM   #1638
Hi Brian,
I will have a look when I get a chance - it may take a while though, as I am very busy at the moment. Double-clicking on the Lpt label to change the flare might be the way to go. To completely integrate the feature into all the wizards etc, would however require a considerable amount of work - I may have some difficulty in justifying it :-).
For the compound horn example you have given, the limitation can of course be overcome simply by using S1, S2 and L12 rather than Ap1 and Lpt, and adding a second segment :-).
Kind regards,
David
www.hornresp.net
Old 10th February 2011, 05:52 AM   #1639
YGM
Thanks GM. I will have a look at the data and let you know by return e-mail if I find anything.
Kind regards,
David
www.hornresp.net
Old 10th February 2011, 11:45 PM   #1640
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Silly question
I've noticed there are many folks posting max SPL and the graphs look strange to me, Is the max SPL feature showing output based on constant current drive, and if so why?
Dan
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
