#1551 |
Mark Kravchenko --- www.kravchenko-audio.com
Mr. T
I'm not so sure of how you get a kerf of 0.050 to begin with. Second. At least over here a plywood panel is 48" x 96". The thinnest blade I have in my shop takes an 0.080 kerf. And I have a great deal of blades over 100 actually. If you had a good piece of plywood with clean edges you could do a center cut loosing 0.125" in total and be left with 23.937 but that is at hit and miss type of situation. Could work though. I have done that in the past in a pinch. I have been in cabinetmaking for most of my life.
Mark |
#1552 |
Thanks guys.
Andrew, you are 100% correct about making the depth under 24" vs 24.5", but as I am using full height (48"), the width matters little as I have some spare on the sides. But usually, I would have cut boards to 23.875" just to make sure they are cut clean. Anyone know if Hornresp will work on a PC with Vista? I have bought a Toshiba Satellite 300 about two years ago and never used it. I may put back to work for HornResp. |
#1553 | |
True edges are important to airtightness. |
#1554 | |
Sorry but I don’t have a mathematical explanation for the difference you are seeing between the Hornresp tapped horn predictions and your measurements. The Hornresp tapped horn power response results are identical to those produced by AkAbak so it would seem that the simulation model is reasonable, even after allowing for the following limitations: 1. The driver diaphragm is assumed to be a rigid plane circular piston. 2. No provision is made for horn transmission losses. 3. Behaviour at all input voltage levels is assumed to be linear. No allowance is made for low frequency high power amplitude compression. Perhaps the observed differences have something to do with the measuring setup, as others have suggested. I am reluctant to add any feature to Hornresp that arbitrarily modifies the results produced by the standard simulation model. Kind regards, David
www.hornresp.net |
#1555 | |
Hi just a guy,
Be assured, I value all feedback regarding Hornresp very highly indeed. Kind regards, David
www.hornresp.net |
#1556 |
Hi Lee,
Hornresp works fine with Vista. Kind regards, David
www.hornresp.net |
#1557 | ||
I'll be happy to comment on 28.30 ASAP, but unfortunately that probably won't be for at least a week. I am still unable to download Hornresp from home due to my dial up connection. You may remember we discussed this before and there was never a resolution. I tried again just now to be sure, it downloaded 295K, said it was done, and when I try to install it gives error message "Zip file is damaged, truncated or has been changed since it was created. If you downloaded this file try downloading again." I'll download 28.30 as soon as I get to a high speed connection and comment on that version. Quote:
#1558 |
I use to have this problem a lot with zip files from certain sites, so sent you a PM with it attached to your hotmail account to see if that might be the problem.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#1559 | |
(Just had to add this note lest you think I was complaining and therefore the most selfish person in the universe.) |
#1560 |
Thank you, sir, very much appreciated. Email received. I'm on the way out the door right at the moment but I hope to be able to try it out by this evening. I'll report back ASAP.
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
