Hornresp
Hornresp
Old 14th December 2010, 01:54 PM   #1501
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Yes.
Mark
www.kravchenko-audio.com
Old 14th December 2010, 02:13 PM   #1502
David_Web is offline David_Web  Sweden
No. Any added resistance should be added to Rg, not Re.
Because TS parameters is relying on Re when calculated.
While you could argue that the result is the same (or at least appears so in the SPL plot) for a single driver, adding a second one will give a wrong result.
And if you recalculate any value after Re they will change to a wrong value as well.
Not to mention the Pe calculation and electrical impedance will be wrong.
Old 14th December 2010, 02:18 PM   #1503
Mark Kravchenko
Hornresp
I never thought about multiple drivers. Good point David.
Hard to argue when you make sense.
Most inductors will not add that much resistance in a single sample but multiplied they will run everything off the rails.
Mark
Mark
Old 14th December 2010, 02:20 PM   #1504
R.I.P.
Originally Posted by Xoc1 View Post
Gentlemen
Simple question?
When adding an inductor to a tapped horn sim, should I add the resistance of the inductor to the Re value, in the same way that I add the inductance to the Le?
Thanks in advance
Martin
yes and the cables too.
regards Andrew T.
Old 14th December 2010, 02:25 PM   #1505
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Gentlemen
Simple question?
Thanks in advance
Martin
Agree with David here-above,
Yes, that procedure would work but its not a good practice because the fundamental T/S would be affected too, i.e. Qes would be more lossy and Qts will thus alter if pressing Sd at the HR main input screen.
IMO: More convenient is to add the inductor resistance to Rg.
b
Old 14th December 2010, 03:53 PM   #1506
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Thanks for all the replies!
I will add the inductor (and cable) resistance to Rg
and the inductance to the Le value
Old 15th December 2010, 05:57 AM   #1507
David McBean is offline David McBean  Australia
Hi David_Web, Mark and Oliver,
Thanks for your feedback on the slider operation. After giving it much consideration I have decided to leave things as they are, at least for the time being.
I have found that the new system is not too bad once you get used to it, particularly if the slider values are set by clicking rather than dragging, and the sensitivity is managed dynamically using the Spacebar key.
The same slider operation is now used for all loudspeaker types. Previously the tapped horn system was different to the others.
The auto / manual settings will continue to default to manual once the Loudspeaker Wizard is closed.
Kind regards,
David
www.hornresp.net
Old 15th December 2010, 06:20 PM   #1508
tb46 is offline tb46  United States
Default Auto v. Manual
Hi David,
I vote for manual over automatic as a default. (I know I don't have a vote, but I can keep on dreaming, can't I?)
Thanks for the latest greatest, it works for me.
Oliver
Old 15th December 2010, 08:02 PM   #1509
Could we at least get the auto/manual toggle buttons on the first page so we don't have to switch pages back and forth every time the wizard is to be used?
Old 16th December 2010, 01:41 AM   #1510
Thawach is offline Thawach  Thailand
Thawach's Avatar
hi david friend
try to sim FLH likes the pic i post above. david friend i want to ask that if the resp freq has a ripple -+ not over than 5 db, i want to know it can work fine. and another one question i see the the F horn on this pic. i'll try to sim and use the OD option. is it all right./
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
