Hornresp
Hornresp
Old 17th June 2008, 03:24 AM   #131
boydon_lepasci is offline boydon_lepasci  United States
Originally posted by aznboi3644
I couldn't get the tapped horn wizard to work.
Just a thought...did you double-click the "Nd" field until it said "TH"? The wizard isn't available until you do this.
Old 19th June 2008, 06:46 AM   #132
Sabbelbacke is offline Sabbelbacke  Germany
I just found something curios.
After simulating a TH, I entered the TH-wizard, played around and left the dialog with "cancel". When I now go into the SPL-Chart and get a sample of SPL, it shows strange values:
Corresponding curve is (don´t mind it, it´s just "in progress")
If I recalculate, SPL is ok again:
Minor, but I thought I mention it
Old 20th June 2008, 12:20 PM   #133
David McBean is offline David McBean  Australia
Hi Sabbelbacke,
Many thanks, I am very pleased that you have taken the trouble to mention it! No bug in Hornresp is minor, as far as I am concerned :-). I will investigate (I think I already know what might be causing the problem), and let you know when it is fixed.
Thanks again, and please keep up the excellent bug-finding work!
Kind regards,
David
www.hornresp.net
Old 20th June 2008, 06:15 PM   #134
aznboi3644 is offline aznboi3644  United States
I figured out how to get the TH wizard to work.
thanks...now just need to figure out everything else lol...I'm getting better though.
Just the lengths and expansions is harder to get a handle on
Old 21st June 2008, 05:52 AM   #135
Hi Sabbelbacke,
The bug has now been fixed - see the latest release, Product Number 1930-080621.
Thanks again for the excellent feedback.
Kind regards,
David
www.hornresp.net
Old 21st June 2008, 06:03 AM   #136
Hi aznboi3644,
That is excellent news, well done!
I knew you would get there eventually - it just takes a little time to understand how the program operates.
Optimising the dimensions of the tapped horn for a given driver is the difficult bit - hopefully the TH Wizard will make the task a little easier for you.
Kind regards,
David
www.hornresp.net
Old 22nd June 2008, 01:41 AM   #137
whats difficult for me is having to keep coverting from metric to inches lol...luckily my cell phone has a unit converter.
I still just need to memorize what all the L1, S12, L34 means...I think I may get the hang of it in a week or two.
Old 22nd June 2008, 09:25 AM   #138
Hi aznboi3644,
All you really need to remember is that 1 inch = 2.54 centimetres :-).
There is no L1 or S12 :-).
S1, S2, S3, S4 and S5 are the cross-sectional areas at the intermediate "throat" and "mouth" points of a four-segment horn.
L12 is the axial length between S1 and S2
L23 is the axial length between S2 and S3
L34 is the axial length between S3 and S4
L45 is the axial length between S4 and S5
When the mouse pointer is moved over any text box on the Input Parameters window, a description is displayed in the status bar panel at the bottom of the window. It should not be necessary to memorise anything.
Kind regards,
David
www.hornresp.net
Old 24th June 2008, 03:21 AM   #139
I see...David, kind sir, thank you for helping me through this. You have been a HUGE help.
Old 24th June 2008, 11:25 AM   #140
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
Default Hornresp companion program
For your interest, I have made a little program to make it easier to move Hornresp records from one computer to another. It is called HornrespMerge, and can be downloaded (free of course!) from my homepage, in the 'SW and Tools' section.
The program can extract one or more records from the usual Hornresp.dat data file, and store it/them in a separate file, or it can take a separate record and insert it into the Hornresp.dat file. Records can be moved up and down, and deleted.
Nothing happens with the Hornresp.dat file until you press Save, and if you inadvertedly delete a record, you can just reload.
I created this program because I have Hornresp on several computers, and often I just want to move a single record from one computer to the other, not the entire data file. Hornresp is a great program (I have been using it for about 7-8 years now), I was just missing this little thing .
As far as I know it is safe to use, but to be absolutely sure, please take a backup copy of the Hornresp.dat file before using it the first time. It has not been tested with every computer configuration yet . Also, please note that it can not run simultaneous with Hornresp.
The decimal separator problem has been taken care of, so it should work with all language settings.
Hope you find it useful, and please report back any bugs. The program has a help file that explains the operation, and where you can also find my email address.
Best regards,
Bjørn
NB: I checked with David that it was OK to post this here .
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2017 diyAudio
