Hornresp - Page 130 - diyAudio
Old 3rd July 2010, 08:39 PM   #1291
grecon is offline grecon  United States
Can the P4S snailshell be modeled in Horn Response?
I'd be curious to see some legit modeling for that box.
Old 3rd July 2010, 08:43 PM   #1292
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
get me the measurements I'd be happy to model it for you.
PASSIONN
Old 4th July 2010, 12:58 AM   #1293
grindstone's Avatar
Default wine
Seems the 27.x series is the end of the road for things to run in wine here.
Haven't had time to reload old versions and debug but I recall 26.x worked.
Anybody else get 27.x going in wine (and if so version details, please) Thanks...
Old 4th July 2010, 06:34 AM   #1294
Default snailshell dimensions
These are one set of dimensions I ran across.
I don't know how to enter this kind of box into Horn Response.
thanks
Old 4th July 2010, 06:48 AM   #1295
brsanko's Avatar
Well this is pretty close of course you'd have to put in the correct specs for your driver but it looks pretty good on the default driver. (don't forget to do combined response).
PASSIONN
Old 4th July 2010, 07:45 AM   #1296
Originally Posted by David_Web View Post
When I try to change power and Xmax in max SPL tool it still takes the previously saved value. So now you have to save the new value every time you want to use it with a different value.
Hi David_Web,
Thanks for this. I must have inadvertently introduced the bug when I added the functionality to permanently save Pmax and Xmax values as part of the data record, in Version 26.50 :-).
I will let everyone know when the problem is fixed.
Kind regards,
David
www.hornresp.net
Old 4th July 2010, 10:07 AM   #1297
Default Hornresp Update
Hi Everyone,
The Maximum SPL bug reported by David_Web has now been fixed. The latest Hornresp release is Product Number 2710-100704.
Kind regards,
David
www.hornresp.net
Old 18th July 2010, 08:40 AM   #1298
Default Hornresp Version 28.00
Hi Everyone,
Hornresp Version 28.00 has just been released. Parabolic horns can now be modelled. Amongst other things, this enables horn segments having two parallel walls and two tapered walls to be more accurately simulated.
My thanks to Bjørn (Kolbrek) for supplying the necessary formulas to calculate the throat acoustical impedance of a finite parabolic horn.
The inclusion of the parabolic horn option required significant changes to the program - could you please let me know if you find any bugs.
Kind regards,
David
www.hornresp.net
Old 18th July 2010, 09:29 AM   #1299
your generosity of your time is never ending.
Thank you.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th July 2010, 11:31 AM   #1300
Mark Kravchenko
mwmkravchenko's Avatar
Thanks David and Bjorn. This will be a very powerfull addition as the horn types mentioned were missing and very usefull. Looking forward to discovering the new features.
Mark
Mark
www.kravchenko-audio.com
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2017 diyAudio
