Hornresp
Hornresp
Old 2nd June 2010, 07:40 AM   #1201
David McBean is offline David McBean  Australia
Originally Posted by BP1Fanatic View Post
I'll check it out today when I log on at work in the office building.
Hi BP1Fanatic,
Just a thought - have you by any chance been using HornrespMerge in conjunction with the latest version of Hornresp? If so, then your data file will most certainly have been corrupted. If you care to send me a copy of your Hornresp.dat file I can check to see if it has been damaged, and possibly fix it for you if the problem is not too severe.
My e-mail address is: dmcbean@bigpond.com
Please note that using HornrespMerge to copy records to the current version of Hornresp will result in corrupted files.
Kind regards,
David
www.hornresp.net
Old 2nd June 2010, 02:08 PM   #1202
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
I'm working on a new release of HornrespMerge now.
Note that the list of records will be scrambled if HornrespMerge does not recognize the format.
Bjørn
Old 2nd June 2010, 06:29 PM   #1203
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Hey dmb, hr was working fine yesterday! When i get off the throne, i'll go back to my desk and check again.
Old 2nd June 2010, 06:42 PM   #1204
GM is offline GM  United States
GM's Avatar
L45 becomes L56 when a compound horn system is specified.
Greets!
Ah! Thanks! Haven't bothered to play with this function yet since IME (limited) experience with them a proper two way is an audibly superior performer.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 2nd June 2010, 06:46 PM   #1205
BP1Fanatic's Avatar
It's all good now! Same laptop hooked up to a docking station at work. As you can see, I'm able to change all the sliders in LW. I think my job's firewall was messing with the program when I was at home
Old 3rd June 2010, 06:36 AM   #1206
Thanks Bjørn.
Would it perhaps be possible to include a warning message in HornrespMerge to indicate when record formats are not compatible?
Also, what happens when a user merges data from several archived files, possibly produced by different versions of Hornresp having differently formatted records?
Kind regards,
David
www.hornresp.net
Old 3rd June 2010, 06:44 AM   #1207
Hi GM,
I agree. Sharing the one driver between two different horns means that there is likely to be a trade-off somewhere along the line :-).
Kind regards,
David
www.hornresp.net
Old 3rd June 2010, 06:48 AM   #1208
It's all good now!
Hi BP1Fanatic,
That was easily fixed :-). Thanks for letting me know that everything is now working okay.
Kind regards,
David
www.hornresp.net
Old 3rd June 2010, 07:06 AM   #1209
Kolbrek's Avatar
Hi all,
A new version of HornrespMerge is available, please see http://folk.ntnu.no/bjorkol.
Yes, there is a message when converting between the formats.
It should be OK, I have added functions to convert between new and old formats. All formats can be interchanged, but when converting to and from the oldest format, some fields may contain erroneous values. When converting between the newest format and the previous one, HornrespMerge just add or remove the Pmax/Xmax fields.
If there are any bugs, please contact me.
Bjørn
Old 4th June 2010, 06:47 AM   #1210
Hi Everyone,
I have tested the latest release of HornrespMerge against all Hornresp data record formats used to date. It works well :-).
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
