#1141 |
Hi David,
I wanted to give you some feedback too: I find it a bit confusing that you have to recalculate a record if you want to see SPL after you calculated the max SPL. Could impulse response be shown again without recalculating it after you close its window? Since it's used so much for subwoofers (and I can't get Homlimpulse to import my stuff) an optional highpass and lowpass would be great! Maybe a single parametric EQ too?Sometimes it's confusing when you want to compare records. Multiple memory slots for comparing could be handy. Best regards, Sladi |
#1142 |
To show the normal record you just empty one field in max SPL tool.
Same with combined response and directivity. To get hi and low pass you have to export it to AkAbak. Regarding the max SPL tool I think I found a bug. Here you can see it with 7mm and 400W. Eg was adjusted to fit inside yet as you see gets way more power than it should. ![]() There are also some difference between SPL tool and what I calculate. 44V and 2.8807Ohm is 672.06W. Tool says 664.3595W. There are also some difference when exporting. At 20Hz I get: SPL sample tool says 88.3379W Ohm is 10.0828 (according to sample tool) and 10.4188 when exported. That gives 192W and 141.84W at 44V. I tried to factor in phase but none of it made sense ether. Did I do something wrong or do I simply not get it? Any way we can get electrical phase when exporting? |
#1143 | |
You're welcome! Thanks for the continuing efforts and yes, no goofy looking plots or at a glance notice any other obvious data mismatches. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#1144 | |||
Hi Sladi,
Kind regards, David
www.hornresp.net |
#1145 |
Hi David_Web,
To allow me to investigate further could you please provide a screenprint of the input parameters window for your test example. Many thanks. Kind regards, David
www.hornresp.net |
#1146 |
Hi David_Web,
Select File > Export > Ze + Phase... from the Electrical Impedance window. Kind regards, David
www.hornresp.net |
#1147 | |
Excellent :-). Incidentally, I have just found another bug inadvertently introduced as a result of the recent set of changes to the program - the second-harmonic distortion figure given in the Sample results is no longer correct. This will be fixed in the next release, after I have investigated the issues raised above by David_Web. Kind regards, David
www.hornresp.net |
#1148 |
Neat, I thought you already got everything when exporting from SPL window.
The max SPL tool was a user error. I think. Forgot I had two drivers in parallel. The tool is per driver right? Although I have seen users putting the combined power of all drivers when using it. Ill attach record later if you still need it. |
#1149 | |
I don't pay any attention to distortion figures, but I see what you mean, a proven high SQ hypex horn design I've built calcs a >100% 2HD......... GM
#1150 |
DMB,
Is there any free space where a field could be added to input a driver's published Pe, Xmax for reference, or better yet, let it auto calc a max SPL plot same as WinISD Pro does? TIA, GM
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
