#1031 |
Hi All, I have a few questions about this project: if you don't mind.
1. how do I determine what size the throat should be? 2. What curve should I use to get the shortest horn? 3. would using more than one segment allow me to go down lower with the same size horn with just one segment? 4. I've thought about using the Beta 8, but only because I've heard it works well with bass horns. Is it good? My biggest issue is having to cross over at 120hz, or there about, to my subs. Seem to high by my intuition. Size is any issue, but a minor one. A friend has a CNC machine so hogging the horn flares out perfect is not an issue and he will not charge me so cost is not an issue either. Thanks in advance. |
#1032 |
Start around 1/2 of Sd or a 2:1 compression ratio. Multiple segments will help you design a flatter response.
#1033 |
Thanks BP. I will do that and see were it goes. I just found out I can get all the wood I need for these for free.....I like free!
#1034 | |
Hi Everyone,
Note that a non-zero length value is still required for the selected flare type to be permanently retained. My apologies for any inconvenience or confusion caused by this bug (which managed to "slip under the radar" for quite some time). Kind regards, David
www.hornresp.net |
#1035 |
David,
Thanks again for such a wonderful product. A couple of questions: 1) What exactly is happening "under the hood" in hornresp when you run a calculation with the Multiple Speakers wizard? It seems to be recalculating based on the new resistance and inductance. But does Hornresp take into consideration the increased physical dimensions associated with multiple speakers, i.e. a larger combined mouth? Does it assume they're stacked vertically, horizontally, etc? 2) In another thread, I recall asking you if you had any plans to make Hornresp more "network aware" in terms of being able to add components into the tuned circuits that comprise the network between amplifier and driver(s) - at the time you said no. But after modeling Tapped Horns for a few weeks, I'm increasingly seeing a need to model in this way, even if there were only the option to insert a single component with RLC values into the network at a given point. Are you able to accommodate this functionality in any way in the future? |
#1036 | ||
Hi letsbangout,
Kind regards, David
www.hornresp.net |
#1037 |
Hi David, thank you for doing all this. I know it is a lot of work and you've done a great job. The other night, I was working in the program and somehow I clicked on one of the boxes and a seperate box came up that allowed me to pick what flare I wanted. I think there were 6 or 7 to chose from. In the past I click on the third box over (don't have the program up at the moment) and hit "T" from tractrix. Since then, I've not been able to find that new window with all the types of flares listed. Where is that???
To anyone, what is the lowest hz front loaded straight non-round horn anyone has modeled and built? I would like to be below 100hz and just can't get my head around how to inturpret the HornResp modeling data. Cheers. Last edited by djn; 8th April 2010 at 02:01 PM. |
#1038 |
#1039 |
#1040 |
It's funny: the bass horns will be the biggest component of my system only to cover from 100hz to 400hz. Seems like a waste...but a good one.
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
