Hornresp
Hornresp
Old 9th March 2010, 03:42 PM   #1011
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Dan
Old 15th March 2010, 03:57 PM   #1012
Jmmlc is offline Jmmlc  France
R.I.P.
Hello,
Elias did a wavelet analysis in order to compare the Impulse Response calculated using Hornresp and the Impulse Response I used to measure at home on one of my horns (Le Cléac'h, Fc = 320Hz, T = 0.707).
The graph where the 2 are compared is at:
http://www.diyaudio.com/forums/attac...1_wavelet2.png
It is taken from a discussion about horns and honkness, see:
http://www.diyaudio.com/forums/multi...ml#post2118791
Best regards from Paris, France
Jean-Michel Le Cléac'h
Old 17th March 2010, 06:52 AM   #1013
David McBean is offline David McBean  Australia
Hi Jean-Michel,
Thanks for the comparison, and for the link. The "Horn Honk" thread is very interesting indeed!
Kind regards,
David
www.hornresp.net
Old 19th March 2010, 06:43 AM   #1014
Default Hornresp Version 26.30
Hi Everyone,
Hornresp Version 26.30 has just been released. The following changes have been made to the Horn Segment Wizard:
* The operation has been standardised for all flare types.
* Some of the less practical oblate spheroidal waveguide options and associated picklists have been removed to simplify matters, and the AT parameter is now more completely integrated into the tool.
* There is no longer a separate 'Specify' option for AT - the various 'Calculate' options now cover all permitted input combinations.
Kind regards,
David
www.hornresp.net
Old 19th March 2010, 12:07 PM   #1015
mwmkravchenko is offline mwmkravchenko  Canada
mwmkravchenko's Avatar
Hi David
You appear to be putting a very fine edge on your software tools. It will indeed make things work to their full potential. It is getting more a more interesting what can bee successfully simulated. And the the accuracy of the simulations is great. Many thanks for your very thorough commitment to the excellence of your program.
Mark
Mark
www.kravchenko-audio.com
Old 19th March 2010, 03:19 PM   #1016
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
It just keeps getting better.
PASSIONN
Old 20th March 2010, 05:12 AM   #1017
Hi Mark and brsanko,
Thanks for your kind words. As you have probably gathered by now, I am a bit of a perfectionist - it can be a real curse sometimes :-).
Kind regards,
David
www.hornresp.net
Old 20th March 2010, 05:47 AM   #1018
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Ain't a d@mn thing wrong with that! We're just lucky that you are!
Old 20th March 2010, 05:58 AM   #1019
www.hornresp.net
Old 4th April 2010, 03:13 AM   #1020
johnr66 is offline johnr66  United States
Default Help a new user
Just downloaded and trying out. I entered all my S values, but it says error L12=0 and will not let me change any L value.
Also, I need to understand how to enter driver parameters.
Specifications: *Power handling: 200 watts RMS/400 watts continuous program *VCdia: 2" *Le: 0.8 mH *Impedance: 8 ohms *Re: 5.1 ohms *Frequency response: 70-4,000 Hz *Fs: 70 Hz *SPL: 97 dB 1W/1m *Vas: 0.6 cu. ft. *Qms: 3.7 *Qes: 0.21 *Qts: 0.20 *Xmax: 6 mm *Dimensions: Overall diameter 8.8", Cutout diameter 7.4", Depth 3.7".
HR needs Sd, Cms, Mmd, Bl, Rms, Nd
Only Re and Le given in above. I guess I need formulas for figuring what HR needs?
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
