Old 16th March 2008, 03:18 AM   #1
Buzzy is offline Buzzy  Singapore
Default Powering Subwoofer
I have 4 ohm single voice coil subwoofer. I have a spare amp at home but it can only drive 8ohm speaker. Can i connect a resistor in series with the subwoofer so that it becomes 8ohm load for the amplifier ?
Old 16th March 2008, 04:16 AM   #2
What kind of amp is it? Is it a stereo amp or receiver, and what kind of power does it deliver?
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 16th March 2008, 05:55 AM   #3
its a kenwood stereo amp with about 40W power 8-16ohms. i am looking for a temporary solution to power my subwoofer.
Old 16th March 2008, 05:09 PM   #4
a 4 ohm resistor is not going to hurt anything as long as it has a high enough power rating. The power rating should be about half of what the amp can deliver. Madisound's 25W Wire-wound resistors are cheap enough ($0.65) that I would get two 8 ohm resistors wire them in parallel to eliminate any risk overheating even with extensive high volume usage. This would allow the resistors to easily withstand the ~80W peak power from the amplifier when wired in series with a 4 ohm driver.
Conventional methods yield conventional results
Old 16th March 2008, 05:31 PM   #5
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
Keep in mind adding a series R will change the frequency response and you will be wasting ~half what the amp is capable of.
If you are using a passive crossover it will also be affected.
Old 16th March 2008, 06:36 PM   #6
I was going to recommend "bridging" your amp so you can drive the sub from both channels, but that won't work here. The sub would either have to be 16 ohms, or your amp channels would have to be able to drive 2 ohm loads. That is not the case here.
Here's the link to the discussion, not that it is going to help you in this application:
How To "Bridge" A Stereo Amp to Just One Channel
As long as this is just temporary, then a 4 ohm resistor is the way to go.
-Anonymous
Old 16th March 2008, 06:39 PM   #7
One more thing. The amp that is going to power your main speakers, not the sub-is that a stero amp or an AV amp?
The reason I am asking is that many AV receivers have a jack in back which carries a bass-only signal to a powered subwoofer. If that is the case, then of course you don't have to worry about a passive crossover for your sub.
-Anonymous
Old 16th March 2008, 07:52 PM   #8
How will it change the frequency response?
how can you waste amplifier power when it is rated at 8 ohms and it will be seeing 8 ohms, with a 4 ohm driver he'll be most likely fry the amp, that would be wasteful.
Old 16th March 2008, 08:23 PM   #9
Hmmm......
Sticking a 4R resistor in series is a very bad idea, driver Qts will
approximately double, not good at all, boombox will be the result.
A stereo amplifier can be wired in parallel (not bridged). Parallel
the inputs and add to each output 0.22/0.33R series resistors
before they are paralleled together. The resistors will ensure
current sharing and take up any gain / DC offset issues.
Each channel will see an 8ohm load (with a 4ohm load).
/sreten.
Old 16th March 2008, 08:51 PM   #10
Just out of curiosity, is your subwoofer a closed box or a ported box?
-Anonymous
Powering a fan for amp Buzzy Parts 8 9th September 2008 01:35 AM
Powering up/down Amp ptah Solid State 14 27th February 2008 06:54 PM
eqt not powering up! marko Car Audio 9 22nd August 2006 11:37 PM
Powering passive subwoofer? NickZ Subwoofers 5 22nd December 2005 12:36 AM
Powering a car amp soundNERD Car Audio 14 29th June 2005 03:40 AM
Page generated in 0.10192 seconds (78.82% PHP - 21.18% MySQL) with 11 queries
