I'm looking to buy a couple of heavy duty subs.
Bit of newb to the equipment side of things, do I buy complete, build myself and do you guys have any advice on brands. Thanks in advance |
#2 |
Speakerholic
You'll have to give us more info on what you need before we can help. Heavy duty doesn't tell us enough. Have you looked at the offerings from mail order houses like Parts Express or someone more local to you?
#3 |
I've had good luck building sonosubs (google sonosub). Lots of info here and on the web, little cabinetry to do (just need to build endcaps and cut the ports.
Output can be prodigious if built correctly. Downside is they can be quite large... ![]() John L.
"...His brain is squirming like a toad..." Jim Morrison |
#4 |
Kinda looking more conventional, a bit like the kind of setup in your avatar cal?!!?
#5 |
Speakerholic
Does conventional mean old? How about these?
#6 |
me likee
#8 |
I'll take a stab,
This will boil down to a few questions that need to be answered before you begin. First, what is the sub's intended use? Music, HT, Live performance, club? If music, what do you listen to. If HT what are you after? Low Low frequency reproduction or bottom end fill? What is the WAF? Is size going to be a limiting factor? What are your wood working skills and what tools do you have available? Likely as important as any question will be what is your budget like? I just built a super cheap sub that could be done considerably cheaper without the ceramic tiles and I am very happy. It isn't super fast and certainly won't mix well with my full range towers, but it wasn't meant to. It was meant to be an HT bottom end fill in sub. (note* not intended to do 15hz). It did exactly what I wanted and more. Granted it's pretty big and VERY heavy. Conventional can go a long way depending on your purposes. Give us some input and I am sure you will get lots and lots of ideas. If you look through all the subwoofer pages on the net, you will find a ton of great designs to build and as many or more to buy. Can you build better for less? I would say yes. But then, I am a builder. Keep us posted on your search Take care, Robert |
| First subwoofer- advice needed please :) | olly-s | Subwoofers | 12 | 5th May 2008 09:38 PM |
| Subwoofer Need Advice | mdrake74 | Subwoofers | 2 | 15th December 2006 11:32 PM |
| !Need URGENT advice! on subwoofer purchase! | Davlaf | Subwoofers | 11 | 12th November 2006 12:25 AM |
| Best TL subwoofer, need advice. | Gunawan W | Subwoofers | 0 | 4th January 2004 01:44 PM |
| Newbie needs PA subwoofer advice | poorbutproud | Subwoofers | 25 | 26th July 2002 03:31 PM |
| Page generated in 0.10401 seconds (77.11% PHP - 22.89% MySQL) with 11 queries |
