Two 10"inch and two 12" inch subwoofers and what to do??
Old 23rd February 2008, 04:54 PM   #1
Gentle1Man is offline Gentle1Man  United States
Unhappy Two 10"inch and two 12" inch subwoofers and what to do??
I have two ten inch subwoofers and two ten inch subwoofers. I want to build two boxes for them. Would a box with a ten and a twelve sealed from each other. I want them to be as accurate as possible.
Infinity Perfect 10.1
Size 10 -inch
Impedance 4 ohms
Cone Material Aluminum
Surround Material Butyl rubber
Sealed Box Volume (cubic feet) 0.6
Ported Box Volume (cubic feet) 1
Port diameter (inches) 3
Port length (inches) 10.4
Free-Air Yes
Dual Voice Coil No
Sensitivity 94dB
Frequency Response 18 - 0.2k Hz
RMS Power Range (Watts) 75-350
Peak Power Handling (Watts) 1400
Top Mount Depth (inches) 5 13/16
Bottom Mount Depth (inches) 6 1/2
Cutout Diameter or Length (inches) 9
Vas (liters) 32.13
Fs (Hz) 28.35
Qts 0.42
Xmax (millimeters) 14.15
Parts Warranty 3 Years
Labor Warranty 3 Years
10"
THIELE-SMALL PARAMETERS
VOICE COIL DC RESISTANCE: REVC (OHMS) . . . . . . 4.11
VOICE COIL INDUCTANCE @ 1 KHZ: LEVC (MH). . . . . . . . 2.96
DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 53.40
SD (CM2). . . . . . . 346.00
MOTOR FORCE FACTOR: BL (TM) . . . . . . . . 16.64
COMPLIANCE VOLUME: VAS (FT3). . . . . . . . . 1.36
VAS (LITERS). . . . . . 32.13
SUSPENSION COMPLIANCE: CMS (ýM/N) . . . . 189.00
MOVING MASS, AIR LOAD: MMS (GRAMS) . . . . 166.71
MOVING MASS, DIAPHRAGM: MMD (GRAMS). . . . 163.01
FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 28.35
MECHANICAL Q: QMS. . . . . . . . . . . . 8.83
ELECTRICAL Q: QES . . . . . . . . . . . . 0.44
TOTAL Q: QTS . . . . . . . . . . . . 0.42
MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . . 0.39
HAG (MM) . . . . . . . . 9.80
VOICE-COIL HEIGHT: HVC (IN) . . . . . . . . . 1.50
HVC (MM) . . . . . . . 38.10
MAXIMUM EXCURSION: XMAX (IN) . . . . . . . . 0.56
XMAX (MM). . . . . . . 14.15
Infinity Kappa Perfect 12.1 12" 4-ohm subwoofer
Size 12 -inch
Impedance 4 ohms
Sealed Box Volume (cubic feet) 1
Ported Box Volume (cubic feet) 1.75
Port diameter (inches) 4
Port length (inches) 12.33
Free-Air Yes
Dual Voice Coil No
Sensitivity 96dB
Top Mount Depth (inches) 6 1/8
Bottom Mount Depth (inches) 6 7/8
Cutout Diameter or Length (inches) 10 15/16
Vas (liters) 83.28
Fs (Hz) 23.32
Qts 0.44
12"
VOICE COIL DC RESISTANCE: REVC (OHMS) . . . . . . 4.00
VOICE COIL INDUCTANCE @ 1 KHZ: LEVC (MH) . . . . . . . 3.05
DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 81.94
SD (CM2) . . . . . . 531.00
MOTOR FORCE FACTOR: BL (TM) . . . . . . . . 16.90
COMPLIANCE VOLUME: VAS (FT3) . . . . . . . . 3.53
VAS (LITERS) . . . . . 99.97
SUSPENSION COMPLIANCE: CMS (ýM/N) . . . . 208.00
MOVING MASS, AIR LOAD: MMS (GRAMS). . . . 224.00
MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . . 216.96
FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 23.32
MECHANICAL Q: QMS . . . . . . . . . . 10.28
ELECTRICAL Q: QES . . . . . . . . . . . . 0.46
TOTAL Q: QTS . . . . . . . . . . . . 0.44
XMAX (MM) . . . . . . 14.15
Old 23rd February 2008, 04:58 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Please tell us your thoughts behind using two different woofers. This is a non-standard practice and it's something I would avoid. Two woofers covering the same frequencies will sound different and it will be very hard to achieve anything accurate because of that.
planet10 needs your help:
Let's help Ruth and Dave
Old 23rd February 2008, 05:15 PM   #3
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
3.5way
sometimes we know very little, and sometimes we know too much
Old 24th February 2008, 04:50 AM   #4
judtoff is offline judtoff  Canada
IMHO sell all 4 and then get something that is more suitable for your application(whatever it is).
Those are decent drivers, but finding one thats more application specific might be better. IIRC they are car audio subs anyways.
:P get some dayton titanics the HiVi 10" sub it looks potent.
Old 26th February 2008, 10:53 PM   #5
I was thinking two sealed enclosures. Two with tens and two with twelves. Used as subwoofers. Do you think this is a problem???
Old 26th February 2008, 10:53 PM   #6
Correction. Four sealed enclosures. A ten inch on top of a twelve inch enclosure on each side under my bookshelf speakers.
Old 27th February 2008, 08:34 AM   #7
Thawach is offline Thawach  Thailand
Thawach's Avatar
hi Gentle1Man
i cannot see the quality with your design. The spl may be high too much more than your bookshelf speaker. sometime you must adjust the volume's lower.
regards
Old 27th February 2008, 09:27 AM   #8
PeteMcK is offline PeteMcK
Here's a way different drivers have been combined before (by Thorsten, iirc):
http://www.fortunecity.com/rivendell...d/dddllqd.html
Your woofers are fairly similar in everything except Vas, so the 'compound driver' approach should work...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 27th February 2008, 10:30 AM   #9
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
What's the problem here? Try it and see if it works, put the drivers in series to make an easy load for the amp, the Qts is close enough as is resonance. Chip board is cheap enough, but use one volume. I have a vented quad box here I use for parties, uses different size woofers with similar resonant frequencies, it breaks all sorts of "RULES" but manages to sound loud and strong, with no nasty discordances.
try 2 X 15 plus 2 X 12 nominal ^ohms load to the amp in a 250 litre ported box. Impotant thing here it was an experiment that "worked"
regards Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 27th February 2008, 10:34 AM   #10
Corax is offline Corax  Germany
Hi Gentle1Man,
according to the TSPs they are all heavy coned car speakers which aren't really capable of reproducing anything above 200Hz IMHO though. I still wonder about the SPLs given in the tables you provided - 94dB for 10" and 96dB for 12"?! At what frequency are they measured. Do you have a frequency plot handy?
Car chassis do go deep down in frequency easily (sometimes even below 20Hz) but with the cost of sound pressure level. That's the reason why enthusiasts desperately need so many kilowatts in their cars to get the (car)body shaking.
My advice would be to use either the 10" or the 12" chassis depending on your desire to get a little more SPL below 30Hz (then use the 12" - diameter is all that matters for sound reproduction at low frequencies) or a smaller enclosure (then the 10" might be the better choice). Neither one has a really noticable advantage over the other one.
My favourite design for such subwoofers would be the following:
Use two chassis in a vented enclosure (preferably bass reflex - with the duct pointing to the floor for instance or on the others sides, or ...) which are mounted on opposing sides. Provide the "cube" with a plate mounted active subwoofer electronic (available in various (internet-)shops) and with various power ratings and amplifier topology. I like those class-D kinda things, because of their less weight and outstanding performance besides efficiency (no big heat sink).
Two 10&amp;quot;inch and two 12&amp;quot; inch subwoofers and what to do??Hide this!Advertise here!
WTB Peerless xxls 12 inch subwoofers elviukai Swap Meet 0 3rd January 2009 09:18 PM
ten inch subwoofers (looking for &lt;35hz response) e-dub Car Audio 19 23rd June 2008 10:36 AM
12&quot; inch woofer suggestions? cujet Multi-Way 35 22nd July 2007 09:53 PM
Copyright ©1999-2017 diyAudio
