Subwoofers - Konfused in Kelowna - Page 3 - diyAudio
Old 24th February 2008, 07:57 PM   #21
Speakerholic
Cal Weldon's Avatar
Originally posted by planet10
A modern HT amplifier will have a subwoofer out which has a low pass (cross-over) function applied to that
Dave,
At our age, modern is a bit subjective. My Harman Kardon HT receiver ( black ) has a straight out (two actually) for the sub, no XO, but it is about 10 years old now. Not sure if they still do it that way.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 24th February 2008, 08:51 PM   #22
Default Their not giving them away, but....
PE has a stand alone Sub Amp . Rated(Claimed) at 512wrms@8, 1024wrms@4. It has standard inputs and a single LFE for RXs with that output. The LFE input bypasses the amps XO, so the driving RX can control those settings. I have not experienced this amp yet, but it has some favorable reviews. Infinately adjustable phase(0-180), Gain, Freq, EQ adjustments as well. Find it here.
Old 24th February 2008, 09:41 PM   #23
frugal-phile(tm)
planet10's Avatar
The amp above is here:
http://www.sound-thinking.org/index....opic=772&st=15
For my needs that is excessive (i'm using 50W per side on my woofers), so i find this one more interesting
http://www.partsexpress.com/pe/showd...number=300-812
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th February 2008, 09:15 AM   #24
dangus is offline dangus  Canada
Originally posted by APLJaK
Assuming I find a suitable amp, do I simply hook it up as Sub Out from my HTAmp to a Line In on the Sub Amp? Then I would drive the Sub from the speaker out of the Sub Amp. My understanding is that the Sub Plate Amps take care of the frequency cross over.
Like the other guys said, the subwoofer out from a surround processor or home theater is already low-passed. On some receivers/processors you can adjust the crossover frequency. If the other speakers are all defined as "Large" in the processor configuration, all that will come out of the sub output will be the .1 track (LFE - low frequency effects). Channels that have the speakers defined as "small" will direct their bass to the subwoofer output.
So, all you should need is an RCA to XLR or 1/4" patch cable. Check the owner's manual for how to wire the cable since it'll probably be going from unbalanced to balanced.
If you prefer stereo subwoofers (and the receiver has preamp outs), you could set the front speakers to "large" and use an external active crossover and power amps for the speakers and send the lowpass from the crossover to the sub amps. IIRC if you set "subwoofer" to "none", all the bass plus the LFE will be directed to the "large" speakers. That's how I used my Technics SH-AC500, since it kept it compatible with analog sources when I bypassed the processor.
The CSS BASH500 is about $240, for 500 watts/4 ohms, one channel. That's about what I paid for a used Behringer EP-2500, which does a fairly honest 650 watts into 4 ohms, stereo. New prices are a bunch higher, enough that it could make more sense just to buy two of the BASH500s, and enjoy the fact that there's no fan to make noise or get clogged with cat hair. Plate or separate, make your choice.
Old 26th February 2008, 09:40 AM   #25
frugal-phile(tm)
planet10's Avatar
Does that imply you no longer have the Technics?
dave
Old 28th February 2008, 03:07 AM   #26
dave
I still have the SH-AC500D, but the DTS decoder died, so I gave in to the dark side and got a Pioneer receiver last year. I've been thinking of using it for a bedroom system.
Old 28th February 2008, 05:11 AM   #27
frugal-phile(tm)
planet10's Avatar
I never use DTS in mine... IIRC it requires centre and i like my 2.1
dave
DVC subwoofers punkrokr1701 Subwoofers 2 24th December 2006 06:12 AM
subwoofers j9184p Subwoofers 1 12th July 2006 03:45 AM
Subwoofers BEAN27 Subwoofers 5 23rd April 2006 10:09 PM
Car Subwoofers? maxdeaf Subwoofers 9 17th September 2003 11:48 PM
Copyright 1999-2017 diyAudio
