Who makes the lowest distortion pro-sound subwoofers?
Old 22nd February 2008, 09:10 PM   #21
iand is offline iand  United Kingdom
Originally posted by thadman
How reasonable would a 30-40hz horn be?
In a single box -- pretty unreasonable... :-)
Ian
Old 22nd February 2008, 10:02 PM   #22
pkm is offline pkm  New Zealand
Big difference between a 40hz horn and a 30hz horn
Note that the labhorn is 850Litres,32hz cutoff, four on the ground or one in the corner.It uses 2 x lab12 woofers.
Old 22nd February 2008, 10:16 PM   #23
Most people would say that 3400l is pretty unreasonable :-)
Ian
Old 26th February 2008, 12:29 AM   #24
thadman is offline thadman  United States
How do horns operate below their cutoff? as direct radiators?
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 26th February 2008, 02:02 AM   #25
Rybaudio is offline Rybaudio  United States
Send a message via AIM to Rybaudio Send a message via MSN to Rybaudio
If you want tons of super low output, I don't see how you can beat a pile of cheap, big woofers IB. For under $900 you could do 8 Mach 5 MJ18s IB.
http://www.mach5audio.com/product_in...c6734e69be3c75
That right there is 8230 cm^2 of surface area that can move about an inch peak to peak with negligible distortion. They're basic, well built drivers- a much better value (in this case) than some of these high tech PA drivers that have a lot of money sunk into lowering distortion that will already be negligible in your case.
Old 26th February 2008, 09:06 AM   #26
Lots of displacement per dollar, but needs a box the size of a garden shed :-)
Ian
Old 26th February 2008, 10:23 AM   #27
MaVo is offline MaVo  Germany
Horn gain doesnt stop directly below cutoff, it is more like smooth rolloff, but yes, front loaded horns with a closed rear chamber behave as direct radiatiors in a closed box if the frequency is low enough. that is because the wavelengths get so long, that the horn becomes acoustically invisible, so only the closed box remains as the enclosure.
Ian
Well, he said IB, didnt he?
Old 26th February 2008, 02:42 PM   #28
The obvious solution seems like a 5-way, but that starts to get quite complex...
IB below 40/50hz
Hornloaded/Ported/Sealed Prosound bass above 40/50hz
Hornloaded looks interesting, but I'm not interested in enclosures >2' wide x >2' tall x >2.5' deep as I'd like to stack them above the midrange enclosure to operate as an array. Upper end XO would be 150-200hz.
Old 26th February 2008, 07:14 PM   #29
How do you arrive at 5 way?
ib < 50hz, woofer < 200hz, midrange < 1khz, 1 inch compression driver < 20khz
you could even skip the midrange with the right midwoofers making it three way.
Old 26th February 2008, 07:22 PM   #30
subwoofer (<40hz)
woofer (>40hz-150hz)
lower midrange (>150hz-600hz)
upper midrange (>600hz-2.4khz)
treble (>2.4khz)
Who makes the lowest distortion pro-sound subwoofers?Hide this!Advertise here!
Lowest noise and distortion Chip Anders_denmark Chip Amps 15 16th June 2006 02:03 PM
What are the lowest distortion cone drivers available? JZatopa Multi-Way 7 7th September 2003 01:10 PM
Copyright ©1999-2017 diyAudio
