Old 17th February 2008, 11:36 PM   #1
DJNUBZ is online now DJNUBZ  United States
Default Considering a DIY horn sub bed frame...
I just moved into an apartment that I will be in for the next year and need a bed frame. I have considered just buying an ikea frame but I am considering making a cheap plywood frame for my bed that is also a horn subwoofer. My thinking is that for the price of a frame I can build a cool project. The max size of the frame would be 53"X76" and should probably be not much thicker then the sub used. I would have to do this very cheap so I would be using the cheapest driver I can find (unless someone has one to donate) and any amp I can find to use which will be low passed by the computer it will be connected to. If I do decide to build this the side of the enclosure that is facing the floor will not have a board, it will use the carpeted floor to seal the enclosure. I don't need huge bass but I want it to be listenable. Normally I would not go with a horn for bass but with the size of my enclosure being able to be so large I figured it might be a fun thing to try. The only other horn or I should say horn like enclosure I have built is the wicked one on the decware site. That sub was unreal for the 2 8" I put it in. I thought about scaling the design up but I would like to keep costs down by only using one sub. Do you guys think this is a worthwhile endeavor? Are there any plans online for something like this that has been done before (I have yet to find any)? Any design or part recommendations?
Old 17th February 2008, 11:54 PM   #2
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
Default Re: Considering a DIY horn sub bed frame...
I don't think you will get acceptable results like that. You should seal the other side.
Old 18th February 2008, 07:00 PM   #3
myhrrhleine's Avatar
Sounds like fun
Just because you can't hear it doesn't mean no one can.
Old 18th February 2008, 10:08 PM   #4
Frode is offline Frode  Norway
Rob van Ede did something like that a few years ago. His website is gone, but here are a couple of archived pages:
http://web.archive.org/web/200301220...old/index.html
http://web.archive.org/web/200301011...reo/index.html
Frode
Old 19th February 2008, 04:08 AM   #5
GM is offline GM  United States
GM's Avatar
Huh! I thought that was Bert Doppenberg's first all horn system. Anyway, isn't qi's B@$3 WC all folded up inside his bed frame? What about a TH with a high Q driver to keep the HF BW < 80 - 100 Hz?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 20th February 2008, 07:18 AM   #6
pkm is offline pkm  New Zealand
What Id do is start with a an affordable 12"
Perhaps something like this
Punisher
http://www.speakerstore.nl/index.php?l=nl&pg=11&c=21
+ a flare extender to reach a little lower,to ~40hz.
Ported would be a hell of alot easier
Old 21st February 2008, 12:14 AM   #7
RobWells's Avatar
Personally I've got to disagree with the punisher suggestion as the only plots I've seen of it looked nowhere near subwoofer duty. (60 hz ?)
Maybe as a 2 way sub with a large ebs below or even a 6th order BP but not on its own.
However maybe the flare extender could change it a lot ?
Personally I'd be looking at either TL's or tapped horns, neither of which I'm any good at designing
Rob.
Old 21st February 2008, 04:02 PM   #8
Instead of the Punisher, the Stepped Horn, using the same driver (and from the same designer) is much more suited for home use. The Punisher is basically ment for >40 Hz, in stacks of 4 or more. The Stepped horn will get a solid 30 Hz on it's own.
http://www.speakerstore.nl/index.php?l=nl&pg=11&c=61
It's longest side is 67", other sides are about 15" each.
From the tapped horns I build so far, nice results for home use are easy to achieve and easy to design, using drivers with Qts between 0.3 and 0.4 (fs ~1/2 octave above cuttoff) and this build model: http://img155.imagevenue.com/img.php...122_1037lo.JPG
With L12 and L34 ~same length (10 -20").
Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 23rd February 2008, 02:06 AM   #9
DJNUBZ,
The carpet won't seal enough to work,I have tried it.
A large bass horn in an apartment could be a problem with the neighbors...
Anyway,here's a plan for a 31 hz horn using the MCM-55-2421 8" driver,$35 from mcmelectronics.
Make the top piece the same size as the mattress,round off the corners to avoid banging your shins.
Not sure what optimum size is for backchamber,maybe 1 cu ft or so.Might even work fine without it.
This is the same driver Bill Fitzmaurice recommends for his AutoTuba,or TableTuba,which might be of interest to you,if you wish to make something more conventional.
http://img244.imageshack.us/img244/4861/bedsubyd0.jpg
Old 23rd February 2008, 03:22 AM   #10
Don that is kinda what I am looking for. Big, cheap and simple. I know that sealing against the carpet is not ideal but I am also kinda using that as a attenuator to keep to much bass from being produced and bothering my neighbors. What I may do is seal the rear chamber of the sub and leave the rest to seal to the floor. Luckily my building has very thick cinder block walls and sound does not transfer and I am on the ground floor.
The MCM sub is the right price but I am curious if you think a tangband sub might be better.
frame double horn for two 8" hm Full Range 12 8th January 2010 01:02 PM
RDH20 frame double horn for two 8"FR hm Full Range 9 3rd July 2009 05:32 PM
Frame bass horn hm Subwoofers 4 24th January 2009 03:36 PM
Frame of the 4 way frontloaded horn system angeloitacare Multi-Way 3 2nd August 2008 12:58 AM
W-Frame or H-Frame dipoles? performace issues? JinMTVT Subwoofers 34 5th October 2006 05:44 PM
Page generated in 0.13957 seconds (83.11% PHP - 16.89% MySQL) with 11 queries
